| Thread Closed |
Mythbusters Death Ray |
Share Thread | Thread Tools |
| May22-05, 09:44 AM | #1 |
Just saw the Mythbuster's ep where they build a fresnel type reflector that focusses the sun's rays. There's a guy online who built a small version of it: SolarDeathRay
Now, there's two things weird about both the construction mechanisms here. 1] In both cases, they calculated the angles of the mirrors, an arduous and finicky task at best. I don't understand why that's necessary at all. Do it empirically! Shine a light on each mirror one at a time and adjust it manually until its beam is at the focal point. Why is that so hard??? Heck, you don't even need fixed parts. I'm thinkin' (at least in the case of the smaller one) a wad of bubble gum will form your base - infinitely adjustable. 2] The Mythbusters were exploring an ancient myth that has a warring race on the Nile or something using a death ray on a Phoenician ship at sea. They declard the myth busted because they couldn't get the apparatus to concentrate enough light to acheive ignition. But their reasons were all purely logistical - all to do with stability and adaptability of the apparatus as well as the problems in aiming at a moving target. It seems to me, that you don't need an apparatus at all. All you need is 300 soldiers holding 300 mirrors. They line up on the shore (creating a 2 dimensional fresnel-type reflector), and they each handle their own focussing. This eliminates all the logistical problems. Every lens is now dynamically and intelligently controlled. OK, so I need 300 volunteers to meet me in the parking lot at the corner of Lakeshore and Brown's Line. Please bring a mirror... |
| May22-05, 11:07 AM | #2 |
i agree that 300 individally controllrd mirrors would probably catch an old sailing ship on fire..
i suppose that the distance from the mirrors to the ship might have a lot to do with it though.. and mirror size also.. |
| May22-05, 11:41 AM | #3 |
well max you'll ever get is 1.4 kW/m^2
now this number might go down due to air convection and mirror conduction to maybe 1.0-1.2 kW/m^2 so its not how many mirrors you got, its the total area and the type of material you are trying to ignite. For the case of wood you would probably need approximately 300 degrees C constant, so thats about 1 sq m of those mirrors |
| May22-05, 11:52 AM | #4 |
| May22-05, 01:04 PM | #5 |
pretty good idea came up when i was fiddling around with this on my notepad..
if one can harness 1.0 kW/m^2 of heat and transform that into steam and then run through power turbines and generate electricity as compared to pvc or solar cells, how much more or less efficient the electro-mechanical method is? |
| May22-05, 01:21 PM | #6 |
OF COURSE!
Sterling Engine! Edit: the mirror alignment with the Sun's normal vector is a hard task, I dont see how this could be achieved without a computerised controller |
| May24-05, 04:06 AM | #7 |
Wasnt it archimedes who came up with this idea? I have no idea whether it would work or not.
| May24-05, 04:51 AM | #8 |
| May24-05, 06:29 AM | #9 |
Mentor
Let's get the history right, it was Archemedes at the siege of Syracuse (Sicily) during the 2nd Punic war.
There is much that is unknown about this, so unless the guys running the Myth Busters show have a mind the quality of Archimedes designing their devices, I do not think that they can honestly say they have busted the myth, only that they were unable to duplicate the feat. Several hundred trained men with mirrors of the appropriate focal length could, conceivably, put a lot of energy in a small area. |
| May24-05, 09:34 AM | #10 |
Recognitions:
I tried this with one of my honrs classes a few years back. Can't say much about ancient ships, but 20 mirrors (about 3 x 5 inches each, and approximately 20 feet away) could not set a dried corn stalk on fire. It burned a few retinas though.
| May24-05, 09:54 AM | #11 |
I was googling Sterling Engine once and came across a company that used the sun to power a Sterling Engine.
dont have the link offhand, it wasnt cheap, but it was very cool.. |
| May24-05, 12:58 PM | #12 |
http://www.nrel.gov/documents/solar_energy.html
About halfway down the page. Also, this company; http://www.pureenergysystems.com/new...olar_Hydrogen/ has produced temps of over 1500oF with an 18-inch mirror! Wood lights up at just 450o |
| May24-05, 01:12 PM | #13 |
Mentor
| May24-05, 01:14 PM | #14 |
that design is a ridiculous waste of land space
roughly twice as big as it should be really |
| May24-05, 03:33 PM | #15 |
| May24-05, 03:37 PM | #16 |
It's a fresnel lens. The flatness of the superstructure is accounted for by the angles of the mirrors (that's what a fresnel lens does.) The reason why it didn't work is becasue it was too flimsy, and they couldn't get all lenses focussed on one spot. You can see when they're moving it, that the superstructure is quite flexible and unstable. |
| May24-05, 03:51 PM | #17 |
no no I meant the area of a focusing mirror. From physics, we know that the maximum amount of solar power we can harness is 1.4 kW/m^2. The area of your telescopic or parabolic mirror is thus the upper limit on how much you can get out of the Sun. The lower limit of course is the clouds and other environmental conditions, plus the Sun's relative angle |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Mythbusters Death Ray
| Pigeons flying in a truck on MythBusters | Classical Physics | 21 | ||
| Mythbusters comic | General Discussion | 4 | ||
| Another Mythbusters experiment | General Physics | 7 | ||
| MythBusters | General Discussion | 14 | ||
| MythBusters season 2 | General Discussion | 37 | ||
