Finding the Optimal Position for a Third Charge
  • Thread starter Thread starter Link
    Charge Position
The discussion centers on determining the optimal position for a third charge to experience no net force between a +5.7 microC and a -3.5 microC charge placed 25 cm apart. It is established that the magnitude of the third charge is irrelevant, as it will cancel out. The correct position for the third charge is calculated to be 0.91 meters beyond the negative charge, where the electric field strength is zero. This conclusion is reached by analyzing the forces acting on the third charge from both existing charges.
  • Understanding of Coulomb's Law
  • Knowledge of electric field concepts
  • Familiarity with charge interactions
  • Basic algebra for solving equations
  • Study Coulomb's Law and its applications in electrostatics
  • Learn about electric field strength and its calculation
  • Explore the concept of equilibrium in charge systems
  • Investigate the principles of superposition in electric fields
Students of physics, electrical engineers, and anyone interested in electrostatics and charge interactions will benefit from this discussion.
Link
quick one
A +5.7 microC and a -3.5 microC charge are placed 25cm apart. Where can a third charge be placed so that it experiences no net force?
I don't know how the book got 0.91m beyond the negative charge, I think its impossible to calculate since the magnitude of the third charge is not given.
You don't need the magnitude of the third charge, as it will cancel.
Write down an expression for the force between the positive charge and the 3rd charge and another expression for the force between the negative charge and the 3rd charge. What can you say if there's no net force on the 3rd charge?
The point at which a charge experiences no net force is the point at which the electric field strength is zero. Find that point. You don't need the magnitude of the third charge.
  • · Replies 21 ·
