Working out energy change during change of moment of inertia
The discussion centers on the energy change experienced by a rotating object, specifically a dancer or a mass on a string, as the moment of inertia decreases and angular velocity increases. The initial calculations using integral force and distance resulted in a logarithmic expression, while the energy change calculated via conservation of angular momentum did not include this term. Participants emphasize the importance of directly integrating the string tension to verify that the work done equals the change in kinetic energy, confirming the principles of rotational dynamics.
  • Understanding of angular momentum conservation principles
  • Familiarity with rotational dynamics and moment of inertia
  • Knowledge of integral calculus for calculating work done
  • Concept of kinetic energy in rotational motion
  • Study the relationship between moment of inertia and angular velocity in rotating systems
  • Learn about direct integration techniques for calculating work done in physics
  • Explore the conservation of energy in rotational motion
  • Investigate the implications of logarithmic expressions in physical calculations
Physics students, educators, and anyone interested in understanding the dynamics of rotating systems and energy transformations in mechanics.
govinda
there's a standard question about the spinning dancer who pulls her hands inward reducing her moment of inertia and increasing her ang. velocity . it seems she had to do some work against the centrifugal force (from momentum and energy equations)
i thought of a simpler example to check if the amt of work that needs to be done agianst the force is indeed equal to the change in energy .considering a particle insted of the ballerina moving in a circle i worked out the work necassary using integral of force times distance moved . i substiuted values for ang. vel. since it isn't constant(from cons of ang momentum eq.) and it worked out to be a logarthmic expression . the change in energy from the first approach was different( no log term) . i have a feeling i have made some fundamental mistake . the calculations seem ok.,
govinda
"if its you against the world bet on the world "
I don't know how you got a logarithmic expression.
Take the simpler case of a mass on a string, rotating on a frictionless table. Let the string pass through a hole in the center of the table, which is the axis of rotation. The string is pulled from below, drawing the mass closer to the center. Calculate the work done by direct integration of the string tension and compare to the the change in KE found from conservation of angular momentum. They should be equal.
  • · Replies 60 ·
  • · Replies 22 ·
  • · Replies 35 ·
9K
