Rotational Dynamics] Quadriceps Muscle Force Calculation
  • Thread starter Thread starter Nb
    Dynamics
The discussion focuses on calculating the force exerted by the quadriceps muscle (M) when a person holds their leg at a 30.0° angle with the horizontal. The weight of the leg below the knee is 44.5 N, and the quadriceps muscle applies force 0.100 m below the knee joint. Using the torque equation τ = rFsinθ, the calculation reveals that the magnitude of M is 44.5 N, balancing the torque created by the leg's weight.
  • Understanding of rotational dynamics and torque equations
  • Familiarity with trigonometric functions, specifically sine
  • Knowledge of force and weight concepts in physics
  • Ability to interpret diagrams related to physics problems
  • Study the principles of torque and equilibrium in rotational dynamics
  • Learn about the application of trigonometric functions in physics problems
  • Explore the mechanics of muscle forces and biomechanics
  • Investigate similar problems involving lever arms and angular forces
Students in physics, biomechanics researchers, and professionals involved in physical therapy or sports science will benefit from this discussion on quadriceps muscle force calculations.
Nb
HELP I HAVE NO CLUE HOW TO DO THIS QUESTION
A person is sitting with one leg outstretched so that it makes an angle of 30.0° with the horizontal, as the drawing indicates. The weight of the leg below the knee is 44.5 N with the center of gravity located below the knee joint. The leg is being held in this position because of the force M applied by the quadriceps muscle, which is attached 0.100 m below the knee joint (see the drawing). Obtain the magnitude of M
(CLICK LINK BELOW TO SEE DIAGRAM)
http://edugen.wiley.com/edugen/courses/crs1000/art/images/c09/nw0356-n.gif [
To calculate the magnitude of the force M applied by the quadriceps muscle, we need to use the equation for torque, which is τ = rFsinθ, where τ is the torque, r is the distance from the pivot point (in this case, the knee joint), F is the applied force, and θ is the angle between the force and the lever arm (the distance between the pivot point and the point of force application). In this case, θ is 30 degrees and r is 0.1 m.
We also know that the weight of the leg below the knee is 44.5 N, which is acting downwards at the center of gravity located below the knee joint. This weight creates a torque in the opposite direction of the applied force, so we need to take this into account in our calculation.
Using the equation for torque, we can set up the following equation:
τ = rFsinθ - r(W)sin(90-θ)
Where W is the weight of the leg and 90-θ is the angle between the weight and the lever arm. Plugging in the values, we get:
τ = (0.1 m)(M)sin30 - (0.1 m)(44.5 N)sin(90-30)
Simplifying and solving for M, we get:
M = (0.1 m)(44.5 N)sin60 / sin30
M = 44.5 N
Therefore, the magnitude of the force applied by the quadriceps muscle is 44.5 N.
13K
14K
13K
