Angular momentum eigenstates and total mom. S?
The total angular momentum S of a spin-2 particle is calculated using the formula J(J+1)|j,m>, where J is the spin quantum number. For spin-2 particles, the eigenvalue of the total angular momentum squared is S^2 = s(s+1)(ħ^2), with s equal to 2. The value of J can range from 0 to 2, necessitating the determination of the specific value of J for accurate calculations. This approach mirrors the treatment of spin-1/2 particles, where the orbital and spin components of angular momentum combine according to standard quantum mechanics principles.
  • Understanding of quantum mechanics principles, particularly angular momentum
  • Familiarity with spin quantum numbers and magnetic quantum numbers
  • Knowledge of eigenvalues and eigenstates in quantum mechanics
  • Basic grasp of the Planck constant (ħ) and its significance in quantum calculations
  • Study the calculation of angular momentum for different spin values, focusing on spin-2 particles
  • Explore the addition of angular momentum in quantum mechanics, particularly for multiple particles
  • Review examples of spin-2 particle systems in advanced quantum mechanics textbooks
  • Learn about the implications of total angular momentum in quantum field theory
Students and researchers in quantum mechanics, physicists working with angular momentum in particle physics, and anyone studying advanced quantum systems involving higher spin particles.
qqchico
My problem is with finding total angular momentum S of a spin 2 particles. My quantum book doesn't do any examples with spin 2 particles do i just do
J(J+1)|j,m> and just plug in j and that will be my value.
Assuming zero orbital angular momentum, L = 0, then the eigenvalue of the total angular momentum squared is just S^2 = s(s+1)*(h-bar)^2, with s = 2.
Generally, the treatment of the problem is the same as with spin-1/2 particles, so the orbital- and spin-components of angular momentum add together as usual in the case of non-zero orbital angular momentum, ie j goes between abs(l - s) and abs(l+s) in integer steps, then l(l+1)*(h-bar)^2 is the eigenvalue of L^2.
Cheyne
Yes, you are correct in your approach. The total angular momentum of a spin 2 particle can be calculated using the formula J(J+1)|j,m>, where J is the spin quantum number and m is the magnetic quantum number. You can simply plug in the appropriate value for J and calculate the total angular momentum. However, it is important to note that the value of J for a spin 2 particle can range from 0 to 2, so you will need to determine the specific value of J for your particle in order to accurately calculate the total angular momentum. Additionally, it may be helpful to consult other sources or textbooks for examples of spin 2 particles to gain a better understanding of the concept.
  • · Replies 17 ·
  • · Replies 35 ·
