Calculate Height of Falling Stone: 2.2m Window in 0.28s
  • Thread starter Thread starter jena
    Falling
The discussion revolves around a physics problem involving the calculation of the height from which a stone falls, given the time it takes to pass a window of a specific height. The subject area is kinematics, particularly focusing on free fall and motion under gravity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the original poster's calculation and the method used to derive the answer. Questions are raised about the notation and assumptions made regarding initial and final velocities, as well as the treatment of acceleration.
There is an ongoing exploration of different interpretations of the problem and the calculations involved. Some participants provide alternative approaches and corrections to the original calculations, indicating a productive dialogue without reaching a consensus.
Participants question the definitions of variables used in the calculations and the assumptions regarding the direction of acceleration. There is also a mention of potential confusion regarding the values derived for velocities.
jena
Hi,
I have a question about height and a falling stone. The question reads:
Question: A stone falling takes 0.28 seconds to travel past a window 2.2 meters tall. From what height above the tope of the window did the stone fall?
Answer: 3.46 meters
Is this the correct answer.
Thank You
i.e. show your work if you want help.
heh, i remember doing that problem out of giancoli years ago.
Work
Sorry here's my work.
Work:
t=0
y(i)=0
v=0
V(i)=7.86 m/s
a= -9.8 m/s^2
y= (v^2-V(i)^2)/2a
y=(0-(7.86)^2)/(2*.9.8)
y=3.46 m
Thank You
Work:
t=0
y(i)=0
v=0
V(i)=7.86 m/s
a= -9.8 m/s^2
What do you denote by v(i) and how did you derived it? If you mean the speed at the top of the window I assume you found it as:
[tex]v_i = \frac{h - \frac{gt^2}{2}}{t}[/tex],
Its value should be 6.49 m/s instead.
Also do not consider accelearation as negative. It is easier to take the y-axis pointing downward to make all vector quantities positive.
jena said:
y= (v^2-V(i)^2)/2a
y=3.46 m
Thank You
Almost there, but you need to arrange a little, as v_i is actually the final velocity for the part of the trajectory from drop point to the top of the window. So,
[tex]h = \frac{v_i^2}{2g}[/tex]
You should get a value of 2.15 m.
Thank you, I see where I got confused
26K
  • · Replies 25 ·
9K
