Are There Multiple Horizontal Tangent Lines to the Curve?
  • Context: Undergrad
  • Thread starter Thread starter Coldie
    Calculus
The discussion revolves around finding horizontal tangent lines to a given curve defined by the equation 2y^3 + 6x^2y - 12x^2 + 6y = 1, as well as determining the coordinates of a point P where a line through the origin with slope -1 is tangent to the curve. The scope includes mathematical reasoning and exploration of derivatives.
  • One participant proposes that the derivative of the curve is \(\frac{4x - 2xy}{x^2 + y^2 + 1}\) and suggests that setting the numerator to zero will yield horizontal tangent lines, leading to the equation \(y = 2\).
  • Another participant introduces the possibility of a subtle solution at \(x = 0\), leading to the equation \(2y^3 + 6y = 1\).
  • There is a discussion about the interpretation of the problem regarding the line through the origin with slope -1, with some participants debating whether it indicates that the curve has a slope of -1 at point P or if it is simply parallel to the curve at that point.
  • One participant suggests that if the line is tangent to the curve, it simplifies the problem, allowing for the removal of either x or y in the derivative equation.
  • Another participant states that the line through the origin with slope -1 can be expressed as \(y = -x\) and emphasizes the need to find a point P on the curve where the derivative equals -1 and satisfies this equation.
Participants express differing interpretations of the problem regarding the tangent line and its implications. There is no consensus on whether \(y = 2\) is the only horizontal tangent line, and the discussion remains unresolved regarding the coordinates of point P.
Participants have not fully explored the implications of the derivative or the conditions under which the tangent lines exist. There are unresolved mathematical steps and assumptions regarding the nature of the curve and the tangent line.
Coldie
I'm given a curve defined by [tex]2y^3 + 6x^2y - 12x^2 + 6y = 1[/tex]
Its derivative is [tex]\frac{4x - 2xy}{x^2 + y^2 + 1}[/tex]
One of the problems is as follows: "Write an equation of each horizontal tangent line to the curve."
I reasoned that if the top of the derivative is equal to zero, the tangent line will be horizontal at that point. Therefore, I solved for [tex]4x - 2xy = 0[/tex]
[tex]4x = 2xy[/tex]
[tex]y = \frac{4x}{2x} = 2[/tex]
This is the only solution I can find, but the wording of the question, "EACH horizontal line" makes me feel as though I'm missing something and there are actually more. Is y = 2 the only one?
The next problem is as follows: "The line through the origin with slope -1 is tangent to the curve at point P. Find the x- and y-coordinates of point P."
Correct me if I'm wrong, but doesn't this mean that we have to solve for x AND y?
[tex]-1 = \frac{4x - 2xy}{x^2 + y^2 + 1}[/tex]
Am I going the wrong way about this, or is there a way to simplify this equation that I'm not seeing?
Thanks.
what about the subtle solution, x = 0? 2y^3 + 6y = 1
Is that saying that the CURVE has a slope of -1 as it passes through the origin? I interpreted it as saying that a line drawn through the origin with a slope of -1 would be parallel to the curve itself at point P...
It's not just parallel, it's tangent...
Oh, I see. Wouldn't x and y be zero then, though?
Why do you say this?
That it's a tangent simplifies things greatly. You knew that at P the slope had to be -1, but you also know that P lies on the line through the origin with slope -1 as well, so you can use this to simplify [tex]-1 = (4x - 2xy)(x^2 + y^2 + 1)^{-1}[/tex] by removing either x or y.
The line through the origin with slope -1 is simply y= -x. You need to find a point P= (x,y) on the curve so that the derivative is -1 and y= -x.
