Complex numbers and modulus problem
The discussion revolves around the conditions under which the equation |z1 + z2| = |z1| - |z2| holds for complex numbers z1 and z2. Participants explore both algebraic and geometric approaches to understand the problem, which involves the modulus of complex numbers.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant proposes that the equation holds when z2 = 0, but questions whether there are other solutions.
  • Another participant references the triangle inequalities and suggests that understanding when equality occurs might provide insights into the problem.
  • A different viewpoint is introduced with the suggestion that z2 can be expressed as -x*z1, where x is a real number between 0 and 1.
  • Participants discuss the equivalence of two sets of conditions derived from manipulating the original equation, with one participant expressing uncertainty about their equivalence.
  • One participant suggests a geometric approach to visualize the problem, while another finds value in algebraic solutions.
  • There is a mention of using polar form of complex numbers as a potential method to solve the problem.
  • Concerns are raised about whether a geometric representation is sufficient for understanding the problem in a test scenario.
Participants express differing views on the sufficiency of geometric versus algebraic methods for solving the problem. While some suggest that the geometric approach leads to a unique solution, others prefer to find an algebraic proof. The discussion remains unresolved regarding the equivalence of the conditions derived from different approaches.
Participants note limitations in their approaches, such as the dependence on specific conditions and the potential for unresolved mathematical steps in their reasoning.
TomMe
Suppose z1 = a + bi, z2 = c + di are complex numbers.
When does |z1 + z2| = |z1| - |z2|? (with || is modulus)
It seems obvious that this is the case when z2 = 0, but are there other solutions? According to the book, no. But after 2 days, I still cannot solve it! :cry:
Here is what I did:
[tex]\sqrt{(a+c)^2 + (b+d)^2} = \sqrt{a^2 + b^2} - \sqrt{c^2 + d^2}[/tex]
Then I squared both sides, remembering that [tex]\sqrt{a^2 + b^2} - \sqrt{c^2 + d^2} > 0[/tex]
If I work this out I get 3 conditions that need to be satisfied:
[tex]1) \sqrt{a^2 + b^2} - \sqrt{c^2 + d^2} > 0[/tex]
[tex]2) ac + bd \geq 0[/tex]
[tex]3) ad - bc = 0[/tex]
I do not see how this can be equivalent with z2 = 0, so I tried another way. Instead of squaring both sides immediately, I made both sides positive:
[tex]\sqrt{(a+c)^2 + (b+d)^2} + \sqrt{c^2 + d^2} = \sqrt{a^2 + b^2}[/tex]
When I work this out, I get 2 conditions:
[tex]1) ac + bd + c^2 + d^2 \leq 0[/tex]
[tex]2) ad - bc = 0[/tex]
I still don't see how this means that z2 = 0, furthermore I suspect that both sets of conditions need to be equivalent but I cannot prove this.
So I actually have 2 requests:
1. Can someone tell me how to solve this?
2. Can someone show me how both sets of conditions are equivalent to each other, if they are? And if they are not, did I make a mistake?
Thanks.
Do you know the proof for the triangle inequalities?
[tex]||z_1|-|z_2||\leq |z_1+z_2|\leq |z_1|+|z_2|[/tex]
If you go through these proofs, you'll might get an idea when equality occurs.
How about z2=-x*z1, where x is real and 0<x<1?
@Galileo: Actually, proving triangle inequality is one of the excercises that come after this one, so I'd like to keep that aside for now..although I'll look at it first thing tomorrow.
@mathman: You're right. If I did it correctly, that gives me [tex](1-x)\sqrt{a^2 + b^2} = \sqrt{a^2 + b^2} - x\sqrt{a^2 + b^2}[/tex]. So that means the solution in my book is wrong, right?
How did you come up with that solution anyway?
:smile:
Think geometrically.
Yes, I got it now. I also found a way to point it out algebraically, just write the complex numbers in polar form and go from there.
One last question though, suppose I get this question on a test or something..does it suffice to draw a picture of the complex numbers as vectors in the complex plane and point out what's happening, or do I need to do it the algebra way?
Somehow just making a drawing doesn't feel like it's complete..
Thanks for the help guys.
Hurky is right. In fact by thinking geometrically, it is easy to see that the solution I gave you is the only solution.
Perhaps you're right (most probably), but I still feel a lot more at ease if I can solve it with equations though. :blushing:
  • · Replies 0 ·
