Calculating magnitude and direction
The displacement from Dallas to Chicago is calculated to be 788.16 miles at an angle of 137 degrees north of east. The law of cosines was applied to determine the magnitude, using the distances from Dallas to Atlanta (730 miles) and from Atlanta to Chicago (562 miles). The initial calculation for direction was incorrectly interpreted in radians, leading to confusion. The correct direction is derived by adjusting the angle to reflect the proper orientation from north of east.
  • Understanding of the law of cosines in trigonometry
  • Knowledge of angle measurement in both degrees and radians
  • Familiarity with vector displacement concepts
  • Basic skills in solving trigonometric equations
  • Study the law of cosines for non-right triangles
  • Learn about converting between radians and degrees
  • Explore vector addition and displacement in physics
  • Practice solving real-world problems involving trigonometric calculations
Students in physics or mathematics, engineers working on navigation systems, and anyone interested in vector analysis and trigonometric applications.
niteshadw
Problem:
A map suggests that Atlanta is 730 mi in a direction of 4.80° north of east from Dallas. The same map shows that Chicago is 562 miles in a direction of 20.9° west of north from Atlanta. Modeling the Earth as flat, use this information to find the displacement from Dallas to Chicago.
Calculate the magnitude in miles and direction in dergees north of east.
For magnitude I have used to law of cosines,
A = 730
B = 562
C = ?
cos C = 180 - (85.2 + 20.9)
so
C = sqrt(A^2+B^2-2(AB)cosC)
C = sqrt(730^2 + 562^2 - 2(730 * 562 * cos(73.9))
C = 788.16 miles
For direction I've tried the following:
sinB/B = sinO/C
so
(562/788)sin(73.9) = 0.685
arcsin(0.685) = 43 dergees
But that did work, am I doing something wrong?
Answer: The displacement from Dallas to Chicago is 788.16 miles in a direction of 43 degrees north of east.
Your calculations for magnitude and direction seem to be correct. However, for direction, the value you obtained is in radians and needs to be converted to degrees. Also, the direction should be measured from north of east, not south of east. Therefore, the correct direction would be 180 - 43 = 137 degrees north of east.
10K
