Calculate sin and cos using complex numbers
The discussion revolves around calculating cos 72° and sin 72° using complex numbers, specifically through the equation (cos 72° + i*sin 72°)^5 = 1. Participants explore various methods to approach this problem without the use of a calculator, including algebraic expansions and geometric interpretations.
  • One participant suggests using the equation (cos 72° + i*sin 72°)^5 = 1 to derive the values of cos 72° and sin 72° but expresses uncertainty about the next steps.
  • Another participant proposes expanding (p + iq)^5 = 1 and collecting real and imaginary parts, leading to a quadratic equation that can be solved for p and q.
  • A different viewpoint emphasizes the usefulness of geometric methods over complex numbers for this problem, suggesting that the geometry of the situation can be understood without complex analysis.
  • One participant mentions that they cannot use Euler's formula as it is not covered in their current study material, indicating a limitation in their approach.
  • Another participant notes the relationship between geometry and algebra, suggesting that drawing diagonals in a pentagon can reveal similar triangles that aid in solving the problem.
  • One participant describes their process of finding the roots of z^5 = 1 and emphasizes the importance of checking which values correspond to the desired angles.
Participants express differing opinions on the best method to calculate cos 72° and sin 72°. While some advocate for algebraic approaches using complex numbers, others argue for geometric methods. There is no consensus on a single preferred method.
Some participants mention limitations in their understanding of geometry and algebra, as well as the dependency on definitions and the specific context of their studies. There are unresolved mathematical steps in the proposed methods.
TomMe
How can I calculate cos 72° and sin 72° using complex numbers, and without the use of a calculator?
I noticed that 5*72° = 360° so (cos 72° + i*sin 72°)^5 = 1. But, I don't quite know how to go from there.. :shy:
What are the 5 independent solutions to the equation
[tex]z^{5}=1[/tex]
And which of the 5 solutions is useless...?
Daniel.
I haven't seen this type of problem before but here's what I'm thinking. Take [itex]cos\theta =p,\, sin\theta=q[/itex]. So expand out [itex](p+iq)^5=1[/itex]. So the imaginary part is 0 and the real part is 1. So collect the multiples of i and substitute [itex]q=\sqrt{1-p^2}[/tex]. You'll end up with something you can solve using the quadratic formula. Then it's just a matter of picking the root that makes the most sense. Remember you're looking for the primitive 5th root of 1. So consider the unit circle and think about which root is close to the real value you are looking for.<br /> <br /> Hope that's helpful<br /> Steven[/itex]
Nifty; that sounds easier than doing some cleverness with a regular pentagon, which is how I figured out I could figure this out!
Okay, I used your approach snoble, and solved it. As for the pentagon, thought about that too but got stuck there.
Thanks all!
Similar triangles are your friend!
euler's formula:
[tex]e^{i x} = cos x + i sin x[/tex]
Unless he started with it,he'll find it pretty useless.I'd say Hurkyl's geometrical method rocks...
Daniel.
Certainly the geometric method is the most straight forward but I didn't suggest it because the question asked about using complex numbers. The geometry of the trig functions can be seen while completely ignoring complex numbers. When it comes to student exercises clearly the process is more important than the result. Yes it is important to understand the geometry of complex numbers but that does not seem to be the point of this exercise.
quetzalcoatl9 said:
euler's formula:
That formula arrives at a later chapter in the book, so strictly speaken I can't use it. :smile:
And my geometry isn't what it used to be. 2 angles of 54° and one of 72°..don't really see how to calculate cos and sin of all this without a calculator and just the drawing, but that's ok. :wink:
At the moment I'm studying algebra and had to review the subject of complex numbers to be able to understand complex matrices, so geometry isn't really a priority right now.
I know that geometry is useful with algebra, but I don't think I'll need it on the exam..I hope.
Thanks again.
The more I learn, the more I get the impression that geometry and algebra are inseparable. :biggrin:
With the geometry problem, what you want to draw are the diagonals... not the lines joining the center to the vertices. You'll get a lot of similar triangles that way.
First know you can do this either by drawing triangles or by expanding sin(5x) and that useing complex numbers (while fun) is not needed. Your observation is the same as the fact that z^5=1 has roots whose real and imaginary parts are cosines and sines of 72°,144°,216°,288°,360°. z^5=1 is hard to solve so let z=x+y i
(x+y i)^5=1
expand the left side. You will notice that the real and imaginary parts look similar with x and y interchanged. Equate real and imaginary parts.
Re((x+y i)^5)=1
Im((x+y i)^5=0
Each part can be made into a one veriable equation using x^2+y^2=1.
Solve for x or y using whichever equation is easier to solve (hint: one is much harder than the other.)
You will get 5 values. (or two if you use 0<x,y<1 for values you want)
Think about which is which one you want.
Or you can check values in the original equation.
use x^2+y^2=1 to get the other value.
Well lurflurf, that's exactly what I did. From the 5 values, one is zero and 2 are negative (if I remember correctly). That leaves us with 2 positive values for both x and y. The way to get the right one is to substitute x or y (can't remember which one) into the other equation. If both sides are not equal, then that's the wrong one. :smile:
  • · Replies 108 ·
13K
