Can Anyone Help Review My Final Exam Problems?
  • Thread starter Thread starter Oxymoron
    Exam Final
The discussion revolves around two questions related to linear operators and sequences in Hilbert spaces. The first question involves proving that a specific linear operator is bounded and determining its norm, while the second question concerns the convergence of a sequence of elements in a Hilbert space.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the properties of linear operators and their norms, with one participant attempting to establish a constraint for maximizing a function related to the operator's norm. Another participant questions the rationale behind using the unit circle as a constraint.
  • In the second question, a participant deduces that the sequence is Cauchy and explores the implications of this on convergence within the Hilbert space, while expressing uncertainty about the existence of a specific limit.
Some participants have provided insights and attempted to clarify concepts, particularly regarding the use of constraints in the first question and the nature of convergence in the second. However, there is no explicit consensus on the methods or reasoning, and some participants express frustration over the lack of responses.
Participants are working under the constraints of a final exam review, which may limit the depth of discussion and exploration of ideas. There is an acknowledgment of correctness in some answers, but uncertainty remains regarding the reasoning behind certain approaches.
Oxymoron
I have a final exam coming up in a few days and I would like some help checking some problems that I have been working through.
Question 1
Consider the linear operator [itex]A:\mathbb{R}^2\rightarrow\mathbb{R}^2[/itex] given by the matrix
[tex]\left(\begin{array}{cc}<br /> -2 & 0 \\<br /> 0 & 1 \\<br /> \end{array}\right)[/tex]
Prove that [itex]A[/itex] is bounded with [itex]\|A\|=2[/itex]
Solution
Okay, here the first thing I did was notice that [itex]A[/itex] is a linear operator, so it takes a 2-element 'vector' [itex](x,y) \in \mathbb{R}^2[/itex] and maps it to another.
So by applying the transformation matrix [itex]A[/itex] to a vector we have
[tex]\left(\begin{array}{cc}<br /> -2 & 0 \\<br /> 0 & 1 \\<br /> \end{array}\right)\left(\begin{array}{c}<br /> x \\<br /> y \\<br /> \end{array}\right)= \left(\begin{array}{c}<br /> -2x\\<br /> y \\<br /> \end{array}\right)[/tex]
So we have that [itex]\|A\textbf{x}\| = 2x+y[/itex] which implies that
[tex]\|A\textbf{x}\|^2 = 4x^2 +y^2[/itex].<br /> <br /> Now I am stuck. I need to prove that [itex]\|A\| \leq M\|x\|[/itex], but I have no methods of proceeding any further.<br /> <br /> I have a idea that maybe we let<br /> <br /> [tex]\|A\|^2 = \max\{4x^2+y^2\}[/tex]<br /> <br /> subject to some sort of constraint. But I have no idea what constraint and even if this is the correct path. Any ideas or suggestions?[/tex]
Okay, what about this...
I need to prove that [itex]A[/itex] is bounded with [itex]\|A\| = 2[/itex]. I know already that
[tex]\|A\|^2 = \max\{4x^2 + y^2\}[/tex]
If I subject it to the constraint [itex]x^2+y^2 = 1[/itex] then after rearranging I have
[tex]y^2=1-x^2[/tex]
Obviously this constaint is the unit circle with domain [itex]-1\leq x \leq 1[/itex], (since [itex]x[/itex] can only vary between -1 and 1).
Therefore...
[tex]\|A\|^2 = \max\{4x^2 + (1-x^2)\}[/tex]
[tex]\|A\|^2 = \max\{3x^2+1\}[/tex]
Since [itex]-1\leq x\leq 1[/itex], this proves that [itex]A[/itex] is bounded with norm 2.
If this is correct then my only gripe is why force the constraint? This method seems a bit illogical to me - but I may be wrong. Any ideas?
I applied the same method to an alternative example.
If
[tex]A=\left(\begin{array}{cc}0 & 2 \\ 0 & 1\end{array}\right)[/tex]
then
[tex]\left(\begin{array}{cc}0 & 2 \\ 0 & 1\\ \end{array}\right)\left(\begin{array}{c}x & y \\ \end{array}\right) = \left(\begin{array}{c}2y & y\\ \end{array}\right)[/tex]
and
[tex]\|A\textbf{x}\|^2 = 4y^2 + y^2 = 5y^2[/tex]
Hence
[tex]\|A\|^2 = \max\{5y^2\}[/tex]
Subject this to the same constraint, ie [itex]-1\leq y\leq 1[/itex]. From this range of values [itex]\|A\|^2[/itex] takes the maximum value when [itex]y=\pm 1[/itex]. And
[tex]\|A\|^2 = 5[/tex]
[tex]\|A\| = \sqrt{5}[/tex]
Why the unit circle?? If I knew this then I'd be a lot happier with the solution to these questions. (by the way, the answers are correct - so you don't have to worry about that).
Is it something to do with the fact that we want to normalize the vectors? Who knows?!
Another question...
Question 2
Let [itex](x_n)[/itex] be a sequence of elements in a Hilbert Space [itex]\mathcal{H}[/itex] for which [itex]\sum_{n=1}^{\infty} \|x_n\| < \infty[/itex].
Show that the sequence of partial sums
[tex]s_n = \sum_{k=1}^{n} x_n[/tex]
converges to a point in [itex]\mathcal{H}[/itex].
So the first thing I deduced is that [itex](x_n)[/itex] is a Cauchy sequence.
This sequence then converges to some element [itex]x_j[/itex]. But I wasnt sure if this [itex]x_j[/itex] was actually in the Hilbert space, and whether or not the sequence [itex](x_n)[/itex] converges to THIS element.
So
[tex]\sum |x_j|^2 = \sum |\lim_{n\rightarrow\infty}x_n|^2[/tex]
[tex]= \lim_{n\rightarrow\infty}\sum |x_n|^2[/tex]
[tex]= \lim_{n\rightarrow\infty}\|x_n\|^2 \in \mathcal{H}[/tex]
[tex]\leq \lim_{n\rightarrow\infty} M[/tex]
where [itex]\|x_n\|^2 < M[/itex].
I know that this [itex]M[/itex] exists because all Cauchy sequences are bounded. So now
[tex]\sum |x_j|^2 = \lim_{n\rightarrow\infty}\|x_n\|^2 \leq M[/tex]
which is an increasing and bounded above. Hence
[tex]\sum \|x_n\|^2 < \sum \|x_n\| < \infty[/tex]
and the sequence converges to a point in [itex]\mathcal{H}[/itex]
I guess no-one knows or has the time. *sigh*
