What Happens if CuSO4 is Added Before Connecting the Power in Electroplating?
The discussion revolves around the process of electroplating, specifically the timing of adding copper sulfate (CuSO4) in relation to connecting the power source. Participants are exploring the implications of adding the solution before the power is applied.
  • Exploratory, Assumption checking
  • Participants are questioning the potential effects of adding CuSO4 before connecting the power, including concerns about short-circuiting and safety hazards. Some share personal experiences with electroplating and express uncertainty about the standard procedure.
The conversation is ongoing, with participants sharing their experiences and raising questions about safety and procedural norms. There is no explicit consensus, but multiple perspectives on the timing of adding the solution are being explored.
Some participants mention prior experiences with electroplating and express concerns about safety, particularly regarding wet conditions when handling electrical components.
ms. confused
I have a question about electroplating a metal object with copper.
Since CuSO4 is normally poured in after the power source is connected, what might happen if it is poured in before? Would there be some sort of short-circuit happening or would it just cause the whole experiment to fail?
well i have never haerd of adding it after. i have eletroplated with copper before and i had a super satrated sultion of copper sulfate i tricked my friend pretty goodwith the mint condistion weate back penny made in 1943 (he was vary goleble)
I agree. Won't pouring it AFTER the voltage is applied create a shock hazard? You know, if your fingers are wet, and you touch the liquid as you're pouring it, the voltage will run UP the flow and into your hands. And also, I've plated a bunch of time in College. The solutions were always ready to go when the voltage was applied.
Second (third ?) that.
9K
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 36 ·
