What Are the Key Properties and Questions About Hilbert Spaces?
  • Context: Graduate
  • Thread starter Thread starter Oxymoron
    Hilbert Hilbert spaces
The discussion revolves around the properties and questions related to Hilbert spaces, including their definitions, characteristics, and comparisons with Banach spaces. Participants explore various aspects such as convergence of sequences, inner products, and the conditions under which certain spaces qualify as Hilbert spaces.
  • Some participants question whether every sequence in a Hilbert space converges and if Hilbert spaces only contain Cauchy sequences.
  • There is discussion about the types of sequences that can exist in Hilbert spaces, including sequences of functions and elements.
  • One participant asks why l_2 is the only l_p space that is a Hilbert space, while others provide differing insights on completeness and inner products.
  • The Cauchy-Schwartz Inequality is discussed, with some asserting it always holds in Hilbert spaces, while others seek clarification on its premises.
  • Participants explore the differences between Hilbert spaces and Banach spaces, noting that Hilbert spaces have inner products that induce norms, while Banach spaces do not necessarily have inner products.
  • There is a proposal that a Banach space can become a Hilbert space under certain conditions related to the norm and inner product.
  • Some participants express uncertainty about the prerequisites for understanding certain spaces, such as measure theory and Lebesgue integrals.
Participants express differing views on several key questions, particularly regarding convergence in Hilbert spaces, the nature of sequences, and the implications of inner products. There is no consensus on many of the raised questions, indicating ongoing debate and exploration.
Some participants mention the need for a textbook or additional resources to clarify definitions and theorems related to Hilbert spaces, indicating potential gaps in foundational knowledge that may affect the discussion.
This discussion may be useful for students and individuals interested in advanced mathematics, particularly those studying functional analysis, Hilbert spaces, and related concepts in mathematical physics.
Oxymoron
A Hilbert Space is a complete inner product space.
My first question: From the definition above, is it safe to say that every sequence in a Hilbert Space converges? And so can we say that Hilbert Spaces only contain Cauchy sequences?
Second question: These 'sequences' that we talk about in Hilbert spaces, can they be sequences of anything? Like sequences of functions, sequences of elements (like complex numbers), sequences of inner products?
Third question: Why is [itex]l_2[/itex], the set of all square-summable sequences, the only [itex]l_p[/itex] space that is a Hilbert space?
Fourth question: The Cauchy-Schwartz Inequality
[tex]|\langle x,y \rangle \leq \|x\|\|y\|[/tex]
This always holds in a Hilbert space right? In which instances does it not hold?
Fifth question: What are the differences between Hilbert Spaces and Banach Spaces? The only thing I know is that Hilbert spaces are 'nicer' than Banach spaces because of something to do with the parallelogram law - which in turn makes Fourier analysis work better or something...I don't really know.
That will do for now.
Consider two spaces:
1. [tex]X_1 = C[a,b][/tex]
2. [tex]X_2 = L_2 [a,b][/tex]
Now consider the inner product defined as
[tex]\langle f,g \rangle = \int_a^b f(t)\overline{g(t)}dt[/tex]
If we induce this inner product into [itex]X_1[/itex] then we will have an inner product space but NOT a Hilbert space because the axiom fails:
[tex]\langle f,g \rangle = 0[/tex]
the inner product can equal zero and f and g don't have to necessarily be 0 themselves.
But now applying the inner product to [itex]X_2[/itex], this does produce a Hilbert space. But I can't see why this one should work and not the other.
You really lack a textbook,right?
It's a matter of understanding definitions first and theorems later.
What's the definition of complete...?Why would this definition imply your first statement/question...?
The elements of a Hilbert space are called VECTORS,because,essentially the H space is a vector space.So all the sequences are sequences of vectors.
For the third question,i'd recommend Debnath & Mikusinski "Introduction to Hilbert Spaces with Applications".Proving completeness for a space (Banach or Hilbert) is not an easy matter.
For #4,what are the premises of that proposition ??
I'll say:"All Hilbert spaces are Banach spaces.Not all Banach spaces are Hilbert spaces".I'll let you dig the literature for the explanation of my assertion.
Daniel.
EDIT: Daniel beat me to it!
No; 'complete' just means that all limit points of convergent sequences in a Hilbert space are contained in the H space. You can still have nonconvergent sequences - they don't define limit points.
By definition, sequences are composed of elements. Of course your H space can be made up of functions (defined between two other spaces) - in which case you get a sequence of functions; but the functions would be elements of the space.
I don't know the answer to your 3rd question.
Yes, it holds on all Hilbert spaces.
Hilbert spaces have inner products, which induce norms. Banach spaces are a more general (less strict) class of spaces, which have norms but not necessarily inner products.
further ref: http://mathworld.wolfram.com/BanachSpace.html.
Thankyou both for replying...
Dextercioby - you are right I have no textbook and it is making understanding my notes upon revision slightly harder than anticipated.
I see. My mistake! Ok, so in other words, sequences in Hilbert spaces are closed under taking limits? And Hilbert spaces can still have nonconvergent sequences - but if they ARE convergent, their limit must be in the Hilbert space.
I see, I see. I have a question about terminology here. You say that a Hilbert space has an inner product which INDUCES an norm. Are ALL norms in a Hilbert space induced solely by inner products?
So when talking about Hilbert spaces, the norm is defined by the inner product
[tex]\|x\| = \sqrt{\langle x,x\rangle}[/tex]
Is this the inner product which induces the norm?
EDIT: Typo now fixed
Why are Hilbert spaces so 'easy' to work with? I mean, I now know that Hilbert spaces are a special case of Banach spaces where the norm is defined by a particular inner product.
Now when are Banach spaces Hilbert spaces? Banach spaces have norms right? So when this norm satisfies
[tex]\|x+y\|^2 + \|x-y\|^2 = 2\|x\|^2 + 2\|y\|^2[/tex]
then the Banach space becomes a Hilbert space with inner product [itex]\langle .,. \rangle[/itex] which induces the norm
[tex]\|x\| = \sqrt{\langle x,x \rangle}[/tex]
Is this a suitable assumption? Or am I simply pulling random memories from the semester? :confused:
EDIT: I'm several posts behind...
Have you already looked at measure theory and Lebesgue integrals? They're necessary prerequisites to define the L2[a,b] space.
If [tex]V= \{ \phi (x) \| \phi:(a,b) \rightarrow C[/tex] and [tex]| \phi | ^2[/tex] is mu-integrable over (a,b)}, then you are CORRECT in thinking that under [tex]\langle f,g \rangle = \int_a^b f(t)\overline{g(t)}dt[/tex] it would NOT be a Hilbert space. There is a way around it - a bit of algebra shows that if instead of using regular equalities "=", you define a different equivalence class (say, '~') where
f~g iff |f - g| = 0 [tex]\mu[/tex]-ae on (a,b) (this stuff is from Cohen, D. p. 15),
then you do get a Hilbert space, specificaly L2[a,b].
In a nutshell, if all the functions in your space are square-mu-integrable, then the only way <f,g> = 0 would be if f=g mu-everywhere (everywhere except at some 'points'); so you use your mu-measure to define an equivalence class where f and g, being equal mu-everywhere, are in the same equivalent class, and so <f,g> =0 if and only if f~g; so you get a Hilbert space.
Could I ask, what textbook are you starting from (and what class will it be for?) I'm using David Cohen's "An introduction to Hilbert space and Quantum Logic), which I'd read for an unnamed elective math class.
All correct.
rachmaninoff, I have no textbook - I am working from my notes that I wrote in class (in fact the class had no recommended textbook - which was kind of strange!?).
The class was called - "Introduction to Hilbert Spaces".
Well, that's why I can't figure it out? I haven't been taught either of those topics. But what you wrote is re-assuring that I was on the right track - at least the right axiom!
I don't believe so, does it necessarily induce a unique inner product satisfying all the conditions for a Hilbert space?
What if I said it was simply a scalar product?
What do scalar products have to do with it?
Well, obviously
is the norm in a Hilbert Space. What I am saying is that a Hilbert space can be defined as a special case of a Banach space.
If you consider the special case when the norm of a complex Banach space satisfies
then, if we only consider this case, the complex Banach space IS a Hilbert space.
Can I say that a Hilbert space is indistinguishable from a Banach space when this is the case?
I have a feeling that maybe I should have a good look into Lebesgue integration and measure theory before I can understand everything about Hilbert spaces, especially how Fourier analysis is involved.
Yes, a Hilbert Space is a special case of a Banach space, just as a Banach space is a special case of a Frenet space (a complete metric space).
A Frenet space!? god damn, how many spaces are there!?
  • · Replies 59 ·
  • · Replies 0 ·
  • · Replies 43 ·
