Fusion related problem (help please, chem final is tomorrow)
The discussion revolves around a chemistry problem involving the heat transfer associated with the melting of ice and the subsequent temperature change of water. The problem specifically addresses the addition of heat to ice at 0.0 degrees Celsius and requires understanding the concept of heat of fusion.
  • Participants explore how to connect the heat of fusion to the overall heat transfer in the problem. There are attempts to apply the formula for heat transfer, but some participants express confusion about the relationship between the heat required to melt the ice and the temperature change of the resulting water.
Some participants have provided guidance on the steps needed to solve the problem, including calculating the heat required to melt the ice before considering the temperature change of the water. Multiple interpretations of how to approach the problem are being explored, indicating an ongoing discussion.
Participants are working under the constraint of a looming exam deadline, which may add pressure to their understanding and problem-solving process. The specific heat capacity of water is mentioned, but there is no consensus on the final outcome of the problem.
mathzeroh
ok my final exam for chem is tomorrow and i need help badly on this practice problem! here it is:
3. When 9.250 kJ of heat is added to 20.0 g of ice at 0.0 degrees celsius, what is the final temperature of the water? The heat of fusion for water is 335 J/g.
I don't know how on Earth to connect the fact that i was given the "fusion" (fusion - huh?) of water with the other stuff. I know that q=(c)(m)(delta T) but how do i connect all this together?
this is what i did (and failed misrebaly):
q=(c)(m)(delta T); m=20.0 g; T initial=0.0 degrees celsius; q=9.250 kJ (which is 9250 J if i wanted to work with the same units)
so:
9250 J=[4.184J/(g*degree celsius)](20.0 g)(T final - 0.0 deg. celsius)
9250 J=(83.68)(T final)
111 deg. celsius=T final
WRONG!
HELP PLEASE! :cry: :rolleyes: :confused:
Heat of fusion, often called "latent heat of fusion" is the amount of heat needed to melt ice without changing its temperature, or the amount of heat you need to remove from water at freezing temperature to change it ("fuse" it) into ice.
Oh, hey thanks a lot.
But how do I relate that bit of information to the problem?
where is everybody?
You figure out how much heat is needed just to melt the ice you started with before you calculate the temperature change of the water resulting from the rest of the heat added.
1. Determine how much of the heat is required to melt the ice- that is the heat of fusion times the mass of the ice.
2. Subtract that from the original 9.25 J to see how much heat is left to raise the temperature of the water.
3. Calculate how many degrees that much heat will raise the water- that is the number of degrees one J of heat will raise 1 g of water times the number of J left times the mass of water.
ans
9.250kJ = 9250J
energy required to melt ice = 335 * 20 = 6700J
energy left after ice has melted = 9250 - 6700 = 2550J
taking specific heat capacity of water to be 4.2 J g^-1 degreeC^-1
therefore heat capacity for 20g of water is 84 J C^-1
increase in temperature = 2550 / 84 = 30.6 degree C
therefore final temperature = 0.0(initial temp) + 30.6 = 30.6 degree C
10K
