Partial Pressures: Just a Few Questions
  • Thread starter Thread starter ~angel~
    Partial
The discussion revolves around equilibrium reactions involving ammonia and ammonium carbamate, focusing on calculating partial pressures and understanding equilibrium constants at specific temperatures.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are attempting to apply equilibrium expressions for Kp and Kc to find partial pressures. There are questions about the stoichiometric ratios and how to handle the cubic relationship in the equations.
Some participants have provided initial equations and attempted calculations, while others are clarifying the relationships between the variables. There is an ongoing exploration of the correct approach to solving the problems, with no explicit consensus reached yet.
Participants are working under the constraints of given equilibrium constants and specific conditions, with some expressing confusion over the calculations involving stoichiometric coefficients.
~angel~
Just a few questions I'm having trouble with.
1.Ammonia is formed from nitrogen and hydrogen according to the following equlibrium reaction:
N2(g)+3H2(g)-->2NH3(g)
The plant operates close to 700K, at which Kp is 1.00*10^-4 atm-2 and employs the stoiciometric ratio 1:3 of N2:H2. At equilibrium, the partial pressure of NH3 is 50 atm. Calculate the partial pressures of the each reactant.
2.Ammonium carbamate (NH2COONH4) is a salt of carbamic acid that is found in the blood and urine of mammals. At 250c, Kc=1.58*10^-8 M^3 for the following equilibrium:
NH2COONH4 (s) <---> 2NH3 (g) + CO2 (g)
If 7.81g of NH2COONH4 is introduced into a 0.500L evacuated container, what is the total partial pressure inside the container at equilibrium at 250c?
Thanks.
1. Kp = (Partial Pressure NH3)^2 / ((PP N2) * (PP H2)^3)
2. Kc = [NH3]^2 * [CO2]
That should get you started.
For 1., I got to [N2]*
^3=2.5*10^7 then I just got lost. I know the ratio is 1:3, but that cubed hydrogen has really put me off.
for ever x atm of N2 there are 3x atm of H2. So (x)(3x)^3=2.5*10^7
So you get 3x^4=2.5*10^7
x= 53.73?
If that's what you meant, apparently it's the wrong answer for N2.
it would be 27x^4=2.5*10^7, you forgot to cube the 3.
lol...thanks for that.
  • · Replies 19 ·
10K
