Gain of the system of amplifiers
The discussion focuses on calculating the overall gain of a signal processing system consisting of a preamplifier, amplifier, and filter. The preamplifier has a gain of 12 dB, the amplifier has a gain of 31 dB, and the filter's input and output voltages are 7.0 V and 0.35 V, respectively, resulting in an overall gain of 17 dB. Additionally, the audience will hear frequencies ranging from 50 Hz to 14 kHz, limited by the loudspeakers' bandwidth despite the rock band's original music bandwidth of 30 Hz to 20 kHz.
  • Understanding of signal processing concepts
  • Knowledge of decibel (dB) calculations for voltage gain
  • Familiarity with audio equipment specifications (microphones, amplifiers, loudspeakers)
  • Basic principles of frequency response in audio systems
  • Study voltage gain calculations using the formula 20log(V1/V2)
  • Research the frequency response characteristics of audio equipment
  • Learn about the impact of bandwidth limitations on audio signals
  • Explore advanced signal processing techniques for audio systems
Audio engineers, sound technicians, musicians, and anyone involved in designing or optimizing audio signal processing systems.
Tino
I need help with the two questions below please because i just don't understand it !1
Questions
1. A signal processing system consists of a preamplifier, an amplifier and a filter connected in series. At a given frequency the preamplifier and the amplifier have gains of 12 dB and 31 dB respectively, while the input and output voltages of the filter are 7.0 v and 0.35v respectively. Calculate the overall gain of the system at that frequency.
2. A rock band produces music with a bandwidth from 30Hz to 20kHz. If the music is amplified through a system with the following bandwidths what range of frequencies will be heard by the audience.
Microphones (10Hz to 12khz), Amplifiers (45Hz to 16kHz), Loudspeakers (50Hz to 14kHz).
Thanks !
I think i have cracked it !
1. voltage gain/loss = 20log V1/V2 = 20log (0.35/7) = - 26dB
And the overall gain is 12dB - 26dB + 31dB = 17dB
2. The audience would hear around 50Hz - 14kHz.
I don't know if my answers are corrected, if it isn't can u please corrected me .
:approve: :approve: :approve: :approve: :approve:
#1 looks good to me. #2 does not. How is a 14kHz signal going to get to the speakers?
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 46 ·
18K
9K
