4 shop vacuum units in a series-parallel arrangement
  • Thread starter Thread starter GENIERE
    Units Vacuum
The discussion centers on the installation of a central vacuum system using four shop vacuum units arranged in a series-parallel configuration. The user aims to achieve superior suction and airflow compared to a factory unit, which has specifications of 125 inches of water and 250 CFM. By utilizing two units in series for suction and two additional units in parallel, the user anticipates improved performance while saving approximately $800. The setup includes a baffled enclosure for minimal filtration, utilizing a 50-gallon trash container to manage debris collection.
  • Understanding of series-parallel electrical configurations
  • Familiarity with shop vacuum specifications and performance metrics
  • Knowledge of airflow dynamics and filtration systems
  • Basic skills in DIY construction and system assembly
  • Research optimal baffle designs for airflow management in vacuum systems
  • Learn about the performance characteristics of different shop vacuum models
  • Investigate the impact of debris filtration on vacuum efficiency
  • Explore advanced central vacuum system designs and their benefits
DIY enthusiasts, home improvement hobbyists, and anyone interested in custom vacuum system installations or optimizing existing vacuum performance.
GENIERE
I’m installing a central vacuum in another house I just purchased. I’m not sure what I’ll do with it but a little improvement should make it a good investment. Rather than use a factory power unit, I’ve decided to use 4 shop vacuum units in a series-parallel arrangement. The highest specifications I could find re: a factory unit is a suction specified as 125 inches of water, and airflow of about 250cfm. The best of the shop vacuum specifications was about 90 inches of water and 150cfm of airflow. Although money is not an issue, savings would be about $800.00 using the 4 shop vacuums ($450.00 vs. $1250.00).
The reason for the multiple units is to increase suction and air flow to exceed the factory unit. Suction increase would be achieved by 2 units in series and to increase air flow, they will be connected in parallel with another 2 units in series. Shop vacuums do not use the debris-laden air for cooling but use fans circulating surrounding air.
Any flaws in above?
I want to use minimal filtration in the system, but some is necessary, as particulates will abrade the vacuum fans. To use only limited filtering, I plan to draw from a baffled enclosure wherein the baffles and volume of the enclosure will sufficiently slow air speed to allow larger particles to drop out. Final exhaust will be outside the house. The enclosure will be a 50-gallon trash container; the lid replaced by the baffle components and the input/output ports. I’d like to have about a 30-gallon debris collection volume.
I would appreciate suggestions for the baffle arrangement.
Why am I re-inventing the wheel? I have no idea. When finished, I’ll probably have spent twice as much money compared to a professionally installed system. Retirement is dangerous. My wife thinks that anything that gets me out of the house is a good idea.
Unless the suction is so big that one of the units in series implodes (probably won't happen) yes that could work.
