New Geometrical Polar-Ring Solution for Magic Numbered Nuclei
The discussion presents a new geometrical polar-ring solution for magic numbered nuclei, specifically addressing the stability of atomic nuclei with neutron or proton numbers of 2, 8, 20, 28, 50, 82, and 126. The proposed model suggests that each magic numbered nucleon possesses a polar axis occupied by an even number of nucleons, forming a coaxial system of circular trajectories. The findings indicate that magic numbers can extend to 178 and 244, and highlight the existence of inner concentric systems within nuclei, particularly for T=82 and T=126, which contain additional nucleons in inner rings.
  • Understanding of nuclear physics concepts, specifically magic numbers.
  • Familiarity with nucleon configurations and their stability.
  • Knowledge of geometrical representations in atomic structure.
  • Basic comprehension of coaxial systems and circular trajectories.
  • Research the implications of magic numbers in nuclear stability.
  • Explore the concept of sub-magic nuclei and their characteristics.
  • Investigate the geometrical models of atomic nuclei beyond T=126.
  • Study the transitional states between different nucleon configurations.
Physicists, nuclear engineers, and researchers in atomic structure and stability, particularly those focusing on the behavior of magic numbered nuclei and their geometrical configurations.
Leo
New Geometrical Polar-Ring Solution for Magic Numbered Nuclei.
It is well known that if the neutron- or proton number within atomic nuclei have the following quantities (2, 8, 20, 28, 50, 82 and 126: the magic numbers), then the atoms are showing a more than average stability. As an example, the element lead PB126 is an integration of two T= 82 and T=126 structures. (figure B)see: http://home.planet.nl/~vuyk0022/App_Vuyk.htm#appendix7
For this new solution: Each magic numbered nucleon is supposed to have a polar axis which is occupied by an even number of nucleons.
This axis is the centre of the coaxial placed symmetrical and globular system of circular trajectories or rings.
The planes of the rings are supposed to be concentric symmetrical and perpendicular to the polar axis.
Each circular trajectory is occupied by even numbers of nucleons, as represented in the figures below.
These figures have to be interpreted as central sections over the axis of the globular nucleus.
The magic number nuclei with 82 and 126 nucleons have a second "concentric inner system" of nucleons.
Number T=82 has only one inner ring with 6 nucleons, and number T=126 has three inner rings with respectively 6,8, and 6 nucleons.
Based on this growing system we may construct and suggest the next magic numbers= 178 and 244.
It would be interesting to study on the intermediate transitional "jump" situations in nature, between these structures.
See the figure B:
There are 7 magic numbered ATOM NUCLEI systematically represented, as a central section through the axis of the more or less globular nucleus, starting with nucleon number: T=2, and in succession T=8, 20.28.50,82 and 126.
The dot sign represents an axial located nucleon.
There are two types of circular located nucleons:
Type A: outer ring located Nucleons: represented in figure B as a closed rectangular with a number X enclosed. This represents a circular trajectory (ring) occupied by X nucleons, concentric with he polar axis of the nucleon.
Type B: so called Inner ring located Nucleons: represented in figure B as a closed rectangular with an internal horizontal striping and an external located number Y. This represents a circular trajectory occupied by Y nucleons, concentric with the polar axis of the nucleon.
For T=2, there are 2 axial nucleons.
For T=8, There are 2 axial nucleons, and 6 ring nucleons= 8.or, as an alternative: 4 axial nucleons, and 4 ring nucleons=8 nucleons.
For T=20, There are 6 axial nucleons, and 14: (4+6+4) ring nucleons= 20 nucleons.
For T=28, there are 8 axial nucleons, and 20: (6+8+6) ring nucleons=28 nucleons.
For T=50, there are 12 axial nucleons, and 38:(6+8+10+8+6) ring nucleons.
For T=82, there are 16 axial nucleons, and 66: (6+8+10+12+10+8+6)+ (6:in the inner ring) ring nucleons=82 nucleons.
For T=126, There are 20 axial nucleons, and 106: (6+8+10+12+14+12+10+8+6)+(6+8+6: in the inner ring)=126 nucleons.
As a result: we may assume that all nucleons should have more or less the same combined structure of Axial and Concentric Ring located Nucleons, as the origin of atomic up or down polarity.
Science news on Phys.org
I made additions to my original article with solutions for so called
Sub-Magic nucleons, see below.
The planes of the rings are supposed to be concentric and
See the figure B:
For T=8, There are 2 axial nucleons, and 6 ring nucleons= 8. Or, as
20 nucleons. Or, as an alternative : 4 axial nucleons and 2x8 ring
nucleons.
nucleons.
So called submagic nuclei, are nuclei which show also a more than
average stability, but less manifest than the magic numbered nuclei.
The numbers found by experiments seem to be: 14,
38,40,64,108,114,120,152, and 162. If we look at the 7 magic numbered
nucleons (see also figure B
http://home.planet.nl/~vuyk0022/App_Vuyk.htm#appendix8 ), it is
obvious that it represents 7 special Polar/Ring shaped moments within
a growing nuclear scheme. As a consequence, there should be
intermediate geometrical structures possible between the seven
different cross sections given in the figure B, with equatorial
symmetry and more or less deformed globular structures.
For T=14, it is assumed that there are 6 axial nucleons and 8 ring
nucleons.
For T=38, there are 10 axial nucleons and 28 (6+8+8+6) ring
nucleons.
For T=40, there are 12 axial nucleons, and 28 (6+8+8+6) ring
nucleons.
For T= 64, there are 16 axial nucleons and 48 (6+8+10+10+8+6) ring
nucleons.
For T=108, there are 18 axial nucleons and 90 (6+8+10+12+12+10+8+6) +
(6+6+6: in the inner ring).
T=114, is assumed to be basically identical with T=126, however
with subtraction of the two inner rings occupied with each 6
nucleons.
T=120, is assumed to be also corresponding with T=126, however with
extension of 2 extra axial nucleons (22 total) and with subtraction
of the single inner ring occupied with 8 nucleons.
T=152, is assumed to be also corresponding with T=126, however with
extension of 4 extra axial nucleons (24 total) and with addition of
an extra "double equatorial ring " (8+14=22 nucleons) adding 26 extra
nucleons to the T=126 nucleus.
T=162, is assumed to be corresponding with T=126, however with
2x double equatorial rings (8+14+14+8=44 nucleons) and under
subtraction of two inner rings of 6 nucleons. As a result this
nucleus should have a cylindrical non-globular form elongated along
the nuclear axis.
(see; Figure B.
http://home.planet.nl/~vuyk0022/App_Vuyk.htm#appendix8 .The schematic
geometrical representation of these nucleons placed in magic number
nuclei)
Leo.
As I expected, I found also possible geometrical solutions for "sub
magic numbered" nuclei.with the nucleon numbers: 14,
So I extended my original article, see below.
See the figure B:
nucleons.
nucleons.
nucleons.
nucleons.
nucleons.
nucleons.
nucleons.
the nuclear axis.
(see; Figure B. The schematic geometrical representation of these
nucleons placed in magic number nuclei)
Leo.
  • · Replies 68 ·
13K
  • · Replies 21 ·
  • · Replies 18 ·
15K
  • · Replies 23 ·
15K
