Can gravitation force change its direction
The discussion revolves around the hypothetical scenario of gravitational force changing direction, exploring the implications and consequences of such a reversal. Participants engage in theoretical reasoning about the effects on objects under gravity, touching on concepts from physics, including inertia and the forces that hold matter together.
  • Some participants question whether gravitational force can change direction and explore the potential consequences of such a change.
  • One participant suggests that if gravity were reversed, an object would accelerate upwards at approximately 9.81 m/s², while also continuing along its previous inertial path.
  • Another participant proposes that reversing gravity could lead to an explosion at a subatomic level due to the lack of gravitational cohesion, while others challenge this by stating that gravity does not hold atoms together.
  • Some argue that gravity exists between all pieces of matter, even in deep space, and question the implications of reversing gravitational attraction.
  • There is a discussion about the forces that hold matter together, with some emphasizing the role of strong and electromagnetic forces over gravity.
  • One participant raises the idea of what would happen if just one object defied the laws of physics in the context of reversed gravity.
Participants express differing views on the effects of reversing gravity, with no consensus on the outcomes or the nature of gravitational force in relation to other fundamental forces. The discussion remains unresolved with multiple competing perspectives.
Participants acknowledge the complexity of the scenario, including the dependence on definitions of forces and the unresolved nature of the consequences of gravity being reversed.
parthivsmehta
force, can force change direction, if so can gravitation force change its direction,
If all gravitational force effecting an object were reversed, it would do far more than just float up off the ground. It would smack into whatever building, tree whatever, rotating at it as the Earth spins toward it. Missing that, it would be left in it's position in space at the time when gravity abandoned it just waiting for some planet or star or whatever to crash into it and burn it up.
Actually, if the effect of gravity would suddenly be reversed the object in question would 'fall' upwards accelerating ca. 9.81 m/s^2. Although gravity would be reversed the inertia of the object would be left intact so the object would also keep moving along its previous path. This previous path is naturally the tangent of the curvature of Earth at the moment gravity was reversed. Knowing when gravity was reversed we could fairly easily calculate the speed (v = vx + vy + vz)of the object as a function of time.
Actually, thinking about it some more, with gravity reversed, the object would probably explode on a subatomic level (no gravity to hold itself together and anti gravity pushing it apart). Then all the pieces would continue seperating in their new inertial path (as Keni correctly pointed out).
Does a comet come apart in deep space? No. So why would anything else? Gravity doesn't 'hold' an atom together, the strong force and electromagnetic force do. Matter just reacts to gravity. So if gravity reversed, we'd all just float off the planet.
We don't know what the consequences would be for gravity being reversed. Objects are attracted to one another, not just to larger objects. Your comet has gravity even in deep space. Gravity is a weak force, but it seems to exist between all pieces of matter.
What does being in "deep space" have to do with a comet holding together? A comet holds together because of the gravitational attraction of each part of it for the others. It is more likely to be disrupted when it is in "near space"- near to the sun or a large planet.
I agree that it is primarily strong and weak forces that hold nuclei together- and the electromagnetic force that holds atoms and molecules together. However at the scale of a "comet", it is gravity that is important.
What I am thinking is that if gravitation is reversed, all of the forces acting on the matter would be disrupted. What would happen if just one object ran counter to the laws of physics?
  • · Replies 54 ·
  • · Replies 29 ·
  • · Replies 51 ·
