Riemann Integrability: Bounded Functions on [a,b]
  • Context: Graduate
  • Thread starter Thread starter steven187
    Riemann
The discussion revolves around the Riemann integrability of bounded functions on the closed interval [a,b], particularly focusing on the implications of discontinuities and piecewise definitions. Participants explore the conditions under which such functions can be integrated, as well as examples and counterexamples related to Riemann integrability.
  • Some participants assert that a bounded function on [a,b] is Riemann integrable if the upper and lower integrals are equal, regardless of continuity.
  • Others express confusion about how to integrate functions that are discontinuous or piecewise defined, seeking examples of Riemann integrable functions that are not continuous.
  • One participant suggests the function defined as 1 for x >= 0 and 0 for x < 0 as an example of a discontinuous but Riemann integrable function.
  • Another participant questions the integrability of a function that is 0 for rational numbers and 1 for irrational numbers, suggesting it is not Riemann integrable.
  • Some participants discuss the relationship between the measure of discontinuities and Riemann integrability, with references to Lebesgue integrability criteria.
  • There is mention of the condition that a bounded function is Riemann integrable if the set of discontinuities has measure zero.
  • Participants clarify that a function can be discontinuous at a point and still be Riemann integrable, as long as the set of discontinuities is appropriately constrained.
Participants generally agree that a bounded function can be Riemann integrable despite being discontinuous, but there is no consensus on the specifics of the conditions required for integrability, particularly regarding the nature and measure of discontinuities.
There are unresolved questions about the definitions and implications of measure zero in relation to Riemann integrability, as well as the distinctions between Riemann and Lebesgue integrability.
Students and practitioners interested in the concepts of Riemann integrability, particularly those grappling with the implications of discontinuities in bounded functions.
steven187
hello all
well I was working through Riemanns Criterion :
let f be a bounded function on the closed interval [a,b]. then f is riemann integrable on [a,b] if and only if , given any epsilon>0, there exist a partition P of [a,b] such that U(f,P)-L(f,P)<epsilon
but there is one thing that I am confused about, riemanns integrability only requires a function to be bounded on a closed interval, if that is the case a piecewise function or a function that is discontinuous at a point which are bounded on a closed interval should be riemann integrable would that be be correct? i just couldn't see how you would intergrate such functions
steven
The bounded requirement guarantees that the upper and lower integrals exist. This isn't enough to declare it riemann integrable, you also need the upper and lower integrals to be equal (or your equivalent statement if you prefer).
A function does not have to be continuous to be riemann integrable.
I see so if a function is not continuous it can still be riemann integrable, the thing is that i don't get is that, I can't see how it is is possible to integrate something which is discontinuous or piecewise and bounded in both cases, do you have any examples of a function being riemann integrable and not continuous at the same time I am just finding it hard to imagine finding the area under the curve of such functions
how about the function which =1 for x>=0 and =0 for x<0? that isn't continuous but it's riemann-integrable.
hmmm.. well I am still confused I just can't imagine how it is possible to find the area of a open shape, and also I can't see how it is possible to integrate
[tex]\int_{-1}^{1}f(x)dx[/tex] if
[tex]f(x)=\left\{\begin{array}{cc}0,&\mbox{ if }<br /> -1\le x\leq 0\\1, & \mbox{ if } 0<x\le 1\end{array}\right[/tex]
Try splitting your partition into two parts -- the intervals on which f is continuous, and the intervals on which f is not continuous, and analyze their behavior separately as the norm of the partition goes to zero.
hello all
well I can't get out how you can find an interval where f is not continuous because it is only discontinuous at one point x=0
now would this function be riemann integrable?
[tex]f(x)=\left\{\begin{array}{cc}0,&\mbox{ if }x\in Q\\1, & \mbox{ if } x\notin Q[/tex]
and what type of functions which are riemann integrable but discontinuous at the same time? I think that would help me understand what riemann integrability actually applies for.
thank you
that function is definitely not riemann integrable. you should prove it; it is the first thing yuo should ever be asked to prove about non-integrable functions.
Now the function that is 0 from -1 to 0 then 1 from 0 to 1
Hurkyl's hint was quite sepcific, that fuction is discontinuous ate exactly one point, zero. the upper and lower riemann sums differ by exactly the width of the interval of the partition containing 0, so obviuosly as the max length of an interval tends to zero the upper and lower sums must converge (to 1)
note a function is discontinuois on a set if it has a discontinuity at any point of that set, not if it is discontinuous at all points of the set. discontinuous is the negation of continuous after all.
If f is discontinuous at x = 0, then f is not continuous on any open interval containing zero. :-p
If I remember correctly...
A bounded function is Riemann integrable if and only if its set of discontinuities has zero area.
i think that's how it goes. a function is riemann integrable if & only if it is continuous almost everywhere, meaning the set of discontinuities has measure zero.
Zero measure sounds better than zero area!
Wait a minute... isn't that the criterion for Lebesgue integrability? Riemann integrability requires a countable set of discontinuities (I think)...
edit: replaced word "definition" with "criterion"
Nah, you can Lesbegue integrate things that are everywhere discontinuous. Every bounded, measurable function is Lesbegue integrable over any set of finite measure. (And some unbounded functions!)
For example, the Lesbegue integral of the salt-and-pepper function over [0, 1] is 1.
edit: whoops never mind
fourier jr said:
that what it means to be continuous "almost everywhere". countable (finite & infinite) sets of real numbers have measure zero. a function is lebesgue integrable if [tex]\int_A f d\mu < \infty[/tex] on a measureable set A wrt a measure [tex]\mu[/tex]
Not quite. A set can be continuous almost everywhere and still have an uncountable set of discontinuities.
hello all
thanxs guys, you have put things into more perspective now about riemann integrability in relation to discontinuities
You're right about the Lebesgue integrability - my mistake.
Wouldn't that mean a function with measure zero of discontinuities could be not Riemann integrable?
edit: That's what I originally meant to say, before bringing Lebesgue into the mess.
No -- because the set of discontinuities doesn't have to be countable, it just has to have measure zero.
I believe the exact condition is that a function on [a,b] is Riemann integrable if and only if the function is bounded and the set of discontinuities has measure zero.
I see, you're right.
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 23 ·
  • · Replies 30 ·
