Physics of Indiana Jones rope swing
The problem involves analyzing the motion of a pendulum, specifically relating to the physics of swinging as demonstrated by a character from a film. The scenario describes Indiana Jones swinging from a rope, with specific parameters such as the length of the rope and the initial angle of swing provided. The objective is to determine the angle after a certain time period.
  • Participants discuss the application of simple harmonic motion (SHM) principles, including the calculation of the period and angular velocity. There are attempts to use the provided equations to find the angle at a specific time, with some participants expressing confusion about their calculations and the correct application of formulas.
The discussion is ongoing, with participants sharing their calculations and questioning the correctness of their approaches. Some guidance has been offered regarding the use of the original equations, but there is no clear consensus on the correct method to arrive at the solution.
Participants note difficulties with the problem despite having the equations, indicating potential misunderstandings of the concepts or misapplication of the formulas. There is a sense of collective struggle within the class regarding the problem.
melissa_y
Indiana Jones!
My physics class had this problem for our homework set this week and nobody has figured it out. We asked for help from our TAs today and they didn't know how to help us either. If someone could look at this problem and tell me what they think I would really appreciate it.
Indiana Jones is swinging from a rope. The distance between the pivot point and his center of mass is 31.00m. He begins swinging from rest at an angle theta=18.00. Assuming that Indiana and the rope can be treated as a simple pendulum, what is the value of theta after 1.290s (in degrees)?
Ok so this is the farthest that any of us have gotten so far...
T= 2pi square root of L/g
theta= theta,o cos((2pi/T) t)
I think these are the equations we are supposed to use but I am still really confused on how to solve this problem. If someone could direct me in the right way and give me the right idea my WHOLE physics class would really appreciate it. Thanks!
Looks like you are applying SHM principles which is good. Find the period and angular velocity and from there just plug it into that bottom equation.
Ok so this is what I've done and I am not gettingthe problem right still...
I did T = 2pi (square root of L/g)
I took that T/2 = 5.5875
Then i set up this equation
5.5875/1.290 = 18/x
Then I solve for x and subtract the x from the theta given. I'm not sure what i"m doing wrong!
5.5875/1.290 = 18/x
The period calculation looks correct. Your last equation is not correct. Why are you not using the equation for theta from your original post?
