Help with Linear momentum problem
This discussion focuses on solving a linear momentum problem involving two particles, A and B, with masses of 9.11x10-31 kg and 1.67x10-27 kg, respectively. The particles are released from rest at a distance of 3.0x10-6 m and their distances are reduced to 1.0x10-6 m. The ratios of their linear momenta, speeds, and kinetic energies are calculated using conservation of momentum and kinetic energy formulas, yielding results of 5.46x1058, 1.38x10-16, and 2.84x1034, respectively.
  • Understanding of linear momentum and the equation p = mv
  • Familiarity with kinetic energy calculations and the formula K = (1/2)mv2
  • Knowledge of conservation of momentum principles in closed systems
  • Basic algebra for manipulating equations and solving for variables
  • Study the principles of conservation of momentum in more complex systems
  • Learn about gravitational and electrical forces and their effects on particle motion
  • Explore advanced kinetic energy concepts and their applications in physics
  • Investigate the relationship between mass, velocity, and energy in particle physics
Students and educators in physics, particularly those focusing on mechanics, as well as anyone interested in understanding the dynamics of particle interactions and momentum conservation.
missrikku
Hello again!
I am having trouble with the following linear momentum problem:
A has a mass mA = 9.11x10^31 kg
B has a mass mB = 1.67x10^-27 kg
They are attracted to each other by some electrical force.
Say they are released from rest with a distance between them of Di = 3.0x10^-6 m
When their distance is decreased to D = 1.0x10^-6 m, what is the ratio of
a) their linear momentums
b) speeds
c) kinetic energies
i know:
p = mv
so for a)
I am looking for: Pe/Pp
mAvA/mBvB
I have mA and mB, but not vA or vB
I know that they are released from rest, but how do you find vA and vB?
Can I use V^2 = Vi^2 + 2a(D-Di) ? If so, how do I find the a?
Thanks. I just need to be pointed in the right direction.
Actually, the phrasing of the questions is a major hint. Notice that the question does not ask for the momenta or velocities of the separate particles but only for the ratios. Also the problem asks first for the ratio of the momenta- if you find that first, the others are easy.
Since the force attracting the two particles to one another is "internal", momentum is conserved- that is, MAvA+ MBvB is a constant.. Since the two particles were initially motionless, what was the initial momentum of each and what was the total momentum (the "constant")?
Hi there,
To solve this problem, we can use the conservation of momentum principle, which states that the total momentum of a closed system remains constant. In this case, the system is closed since there are no external forces acting on A and B.
a) To find the ratio of their linear momentums, we can use the equation p = mv. Since they are released from rest, their initial momentums are both zero. When their distance is decreased to D = 1.0x10^-6 m, their final momentums can be calculated using the equation p = mv again. So the ratio of their momentums will simply be the ratio of their masses, since their velocities are the same. Therefore, Pe/Pp = mA/mB = 9.11x10^31/ 1.67x10^-27 = 5.46x10^58.
b) To find the ratio of their speeds, we can use the equation v = sqrt(2K/m), where K is the kinetic energy and m is the mass. Since the initial kinetic energy is zero, we can only calculate the final kinetic energy using the equation K = (1/2)mv^2. Plugging in the values, we get K = (1/2)(1.67x10^-27)(v^2). To find the speed, we can rearrange the equation to v = sqrt(2K/m). So the ratio of their speeds will be vA/vB = sqrt(mB/mA) = sqrt(1.67x10^-27/9.11x10^31) = 1.38x10^-16.
c) Finally, to find the ratio of their kinetic energies, we can use the equation K = (1/2)mv^2. We already have the values for m and v from the previous calculations, so we can plug them in to get the kinetic energies for A and B. The ratio of their kinetic energies will be Kp/Ke = (1/2)mA*vA^2/(1/2)mB*vB^2 = (mA*vA^2)/(mB*vB^2) = (mA/mB)*(vA/vB)^2 = 9.11x10^31/1.67x10^-27 * (1.38x10^-16)^2 = 2.84x10^34.
I hope
  • · Replies 62 ·
14K
18K
