Understanding Initial Conditions for Solving Pendulum Motion
  • Thread starter Thread starter EvLer
    Initial Pendulum
The problem involves analyzing the motion of a pendulum with a length of 0.5 meters, initially displaced at an angle of 0.1 radians and released from rest. The discussion centers around the formulation of the second-order differential equation governing the pendulum's motion.
  • Participants discuss the initial conditions required for solving the differential equation, particularly questioning the value of the angular velocity at the start. There is an exploration of the meaning of derivatives in the context of angular motion.
Some participants have provided insights into the initial conditions, noting that the angular velocity at the moment of release is zero. The conversation is ongoing, with various interpretations of the initial conditions being explored.
Participants are clarifying the definitions and roles of initial conditions in the context of second-order differential equations, with an emphasis on the specific requirements for this pendulum problem.
EvLer
The problem:
L = 0.5. Pendulum of L is displaced angle of 0.1 rad and then released from rest. Determine resulting motion.
Ok, so I know it's going to be a second order DE of this kind which I will need to solve:
theta''(t) + (g/L)theta(t) = 0;
so theta(0) = 0.1? then what about theta'(t)(0)? is it just = 0? and what is it exactly anyway? if derivative is a rate of change with respect to time? rate of change of angle?
Thanks for any explanation/source.
"Released from rest".Does that ring a bell...?Remember that it's a circular movement,linear velocity is ~ to the angular one.
Daniel.
EvLer said:
The problem:
[tex]\dot{\theta}(t) = \omega[/tex]
is the angular velocity of the pendulum, and the initial value is zero, as you have observed
when you solve this problem for a variable. theta in this case
the first initial condition is the initial state of the variable of interest
the second initial condition is the first order derivative of the variable
the third initial condition is the 2nd order derivative of the variable and so on.
This is provided we have a single variable of n-th order.
If this is so then there are:
n initial conditions
The first is always the zeroth derivative of the variable of interest
the last is always the n-1 derivative of the variable of interest.
This our IC's are
theta0 = 0.1 rad
thetadot0 = 0 rad/s
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 26 ·
