Help me find angular velocity and change in Kinetic Energy
The discussion revolves around calculating the final angular velocity and change in kinetic energy when two wheels, A and B, merge. Wheel A has an initial angular velocity of 35 rad/s and a moment of inertia (I) of 25 kg*m², while wheel B has an I of 15 kg*m² and is assumed to start at rest. The conservation of angular momentum is applied to determine the final angular velocity after the wheels stick together. The kinetic energy is calculated using the formula K.E. = 1/2 I ω² for both initial and final states.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with moment of inertia calculations
  • Knowledge of kinetic energy formulas in rotational dynamics
  • Basic proficiency in algebra for solving equations
  • Study the principles of conservation of angular momentum in detail
  • Learn how to calculate moment of inertia for various shapes
  • Explore the derivation and application of kinetic energy formulas in rotational motion
  • Practice solving problems involving multiple rotating bodies merging
Physics students, mechanical engineers, and anyone interested in rotational dynamics and energy conservation principles will benefit from this discussion.
samemikejones
got a real tricky but fun problem, wheel A is going 35 rad/s, with I = 25 Kg*m2 and merges into wheel B with I = 15 Kg*m2, if they stick together at contact, find its angular velocity and change in Kinetic Energy...
PlEASE HELP:
So far, I have L = IW, or 8.8 x 10^2 kg m2/sec
and L = IW for oval to be at 9.8 x 10^2 kg m2/sec,
w = L/I
need some guidance from here...PLEASE HELP..!
PlEASE HELP:
w = L/I
Your first computation for the angular momentum looks fine. I have no idea where your second line comes from. The problem is not specific, but I assume they indend for you to assume wheel B starts at rest. The two wheels together have greater moment of inertial than either one separately. Angular momentum must be conserved. How do calculate the kinetic energy?
samemikejones said:
K.E. = 1/2 I omegah squared
OK, so you have an initial [tex]\omega[/tex] for each wheel. Use conservation of angular momentum to find their final [tex]\omega[/tex] and calculate the initial and final energies.
