Solving Mixing Problem with DE: Initial Values & Flow Rates
  • Thread starter Thread starter EvLer
    Mixing
The discussion revolves around a mixing problem involving differential equations related to a tank containing salt water. The tank initially holds 100 gallons of salt water with a specific amount of salt, and various flow rates of salt and fresh water are introduced, leading to a need for formulating an initial value problem for the amount of salt over time.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the formulation of the differential equations governing the amount of salt in the tank, questioning the rates of salt entering and leaving the tank. There is uncertainty about how to account for the changing concentration of salt as fresh water dilutes the solution. Some participants suggest combining flow rates and express concerns about the implications of changing volumes over time.
Multiple interpretations of the problem are being explored, with participants offering different formulations of the equations. Some guidance has been provided regarding the setup of the differential equations, but there is no explicit consensus on the final approach or solution. Participants are encouraged to understand the concepts behind the equations rather than simply replicating them.
Participants note the initial conditions and the rates of flow into and out of the tank, emphasizing the importance of understanding how these factors influence the concentration of salt over time. There is an acknowledgment of the complexity introduced by the fresh water flow and its effect on the overall concentration.
EvLer
I am not really sure how to get right values for variables/constants:
A tank contains 100 gallons of salt water which contains 10 lbs of salt. A salt solution of 2 lbs salt per gallon enters the tank at a rate of 3 gallons perminute while a flow of fresh water runs into the tank at rate 5 gallons per minute.
The well-stirred solution runs out of the tank at rate of 7 gall/min. Let A(t) be the amount of salt in lbs at time t in mins. The initial value problem for A(t) is ...
(to be found as a DE with IC).
V(0) = 100
r2(flow rate) = 7 gall/min
A(0) = 10 gal.
The underlined section is where I need some help, at least then I can start on the problem and see how I end up.
Thanks in advance.
EvLer, I'll take a chance on this one because I'm not sure. See what you think and maybe others can help too:
Isn't the time rate of change of the amount of salt s(t) in the tank:
[tex]s^{'}(t)=\quad\text{salt in rate}\quad-\quad\text{salt out rate}[/tex]
I tell you what, that fresh water just makes it more complicated. Isn't it the same as if they were just one pipe putting in 8 gal/min with a total of 6 pounds salt/minute?
So the rate of salt in is just 6.
Now for the rate out: Well, it's the number of gallons out times the concentration of salt in the tank at time t. The concentration is the amount of salt which is s(t) divided by the total volume. Note that 8 goes in but only 7 goes out. So isn't the volume a function of t? It's 100+t in fact. Can you put it all together? Note the initial conditions: s(0)=10. Use your best judgement; I'm not sure. :smile:
Thanks for your reply, saltydog :smile:
We have 2 equations that are used in these problems:
dV/dt = rate_in - rate_out;
so: V = (rin - rout)t + C;
C is not hard to find given V(0) = 100.
Then second equation is: (A is amount of stuff in the liquid, r - rate, c - concentration)
dA/dt = rincin - routcout;
where cout = A(t)/V(t);
So, basically I need to figure out rates and cin.
I wasn't sure if I could just add rate of fresh water and salty water but i think it makes sense, like you said. But don't you think that increasing the rate of flow with salty water being diluted in this case, it's concentration is going to decrease rather than increase per unit of volume at a point in time? Although I think it's supposed to be constant, concentration that is, given rates are constant.
Or maybe I am turned around :confused:
Well Evler, haven't worked mixing problems in a while but interesting nevertheless. This is what I come up with:
Using the analysis I gave above, I get for the "amount" of salt in the tank as a function of time s(t):
[tex]s^{'}=6-7\left(\frac{s}{100+t}\right);\quad s(0)=10[/tex]
little of this, little of that, we obtain:
[tex]s(t)=\frac{3}{4}(100+t)+\frac{c}{(100+t)^7};\quad c=-65(100)^7[/tex]
The first plot is the amount of salt in the tank as a function of time. Now, the concentration as a function of time is:
[tex]\frac{s(t)}{100+t}[/tex]
The second plot is the concentration of salt as a function of time.
Edit: Oh yea, if I'm right, don't just copy my work ok. Make sure you understand the concepts, why I set up the equations like I did, how to integrate it, and does the resulting equations make "intutitive" sense. :smile:
Yes, that's correct. As saltydog told you, salt is coming in at 6 pounds per minute and going out at 7A(t)/(100+t)
The differential equation for the amount of salt A(t) is
dA/dt= 6- 7A/(100+t).
No, the concentration will not be a constant- whether it is increasing or decreasing depends on the original concentration and I haven't calculated the solution to see what happens. In this problem, the initial concentration of salt is 1/10 pound of salt per gallon of water. The concentration of salt coming in is 2 pounds in 8 gallons of water (yes, you can treat this as a single pipe): 1/4 pound per gallon. The concentration of salt in the tank will increase toward a limit of 1/4 pound per gallon. If the concentration of salt in the tank initially had been greater than 1/4 pound per gallon, it would decrease toward that limit.
You know what EvLer, I think I did your homework for you and I very much don't want to go against forum rules. Really, you know what, I say you do a different one now:
Initially, a 200 gal tank contains 40 lbs salt. A pipe going into the tank is flowing at 5 gal/min with a conc of salt at 2 lbs/gal. Another pipe is flowing out at the same rate. Find the amount of salt s(t) in the tank at time t. Yep, full report by morning. :smile:
:biggrin:
although this isn't really homework, it's a practice exam.
Thanks much for help!
:biggrin: :biggrin:
Deal!
Here's what I have:
dV/dt = rin - rout;
V(t) = C, V(0) = 200 => V(t) = 200;
dA/dt = rincin - routA(t)/V(t);
A(t) = e(-5/200)t[400*e(5/200)t + C];
given A(0) = 40 => C = -360
A(t) = e(-5/200)t[400*e(5/200)t - 360];
Are you taking points off for abscense of plots?
EvLer said:
:biggrin:
:biggrin: :biggrin:
Deal!
Here's what I have:
dV/dt = rin - rout;
Very good EvLer. Actually I do reqest a plot, that is if you have Mathematica handy. You know LaTex code makes everything look nicer and easier to read. Like this:
[tex]A(t)=400-360e^{-0.025t}[/tex]
Erm, I think I just got me a "B" :sad:
We have MATLAB on school machines, but I need to get there first. Perhaps if you give me some time...
Yeah, I can do simple things with LaTex, can you direct me to a short tutorial on how to use it for various kinds of expressions, like fractions, matrices, etc. If you hold your cursor w/t clicking on the thread that uses LaTex you can see the code used, but tutorial would be nice.
Thanks again!
Thanks again!
EvLer, don't go out of your way for the plot. It's just a suggestion. There is a thread in the General Physics forum called "Introducting LaTex". It has lots of examples and some web references.
  • · Replies 16 ·
  • · Replies 23 ·
