Why is the electric potential constant inside a spherical conducting shell?
  • Context: Undergrad
  • Thread starter Thread starter Corneo
    Conductor Potential
The electric potential inside a spherical conducting shell is constant due to the absence of an electric field, as established by Gauss's Law. When the electric field (E) is zero, the potential (V) must remain constant throughout the interior of the shell. This constancy is further supported by the relationship E = -dV/dR, indicating that a zero electric field results in no potential difference. Consequently, the potential inside the shell is equal to the potential on its surface, preventing charge movement.
  • Understanding of Gauss's Law
  • Familiarity with electric fields and potentials
  • Knowledge of calculus, specifically derivatives
  • Basic concepts of electrostatics
  • Study Gauss's Law applications in electrostatics
  • Explore the relationship between electric fields and potentials in different geometries
  • Learn about the implications of electric potential continuity
  • Investigate charge distribution on conductors in electrostatic equilibrium
Students of physics, electrical engineers, and anyone interested in understanding electrostatics and the behavior of electric fields in conductive materials.
Corneo
Consider a spherical conducting shell where all the charges reside on the surface. Using Gauss's Law, it can be found that the electric field inside the shell is zero. But why is the electric potential a constant? More over, why is the potential same as the potential on the surface of the shell? Please refer to the voltage plots in the following link.
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
Thank you.
The electric field is just the derivative/gradient of the potential:
[tex]E = \nabla V[/tex]
So where the electric field vanishes, V must be constant. And V must be continuous everywhere (unless E is infinite).
Thank you.
The relation between Electric Field and Potential is given by:
[itex] <br /> E=- \frac{dV}{dR}[/itex]
When E =0 , then from the above expression the potential has to constant.
Because everywhere inside the shell the electric field is zero, therefore everywhere inside it , potential is constant and same . If there are two different potentials between two different points, then due to potential difference the charges on the sphere might start moving, which is not the case when E=0.
  • · Replies 23 ·
  • · Replies 22 ·
