Is Every Eigenstate of L^2 an Eigenstate of Lz?
  • Thread starter Thread starter Henk
    Operators
The discussion revolves around the relationship between eigenstates of the angular momentum operators L^2 and Lz in quantum mechanics. Participants explore whether every eigenstate of L^2 is also an eigenstate of Lz, referencing the properties of commuting operators and the implications of degeneracy.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants examine the implications of commuting operators and the existence of common eigenstates. Questions arise regarding the nature of degenerate eigenstates and their relationship to Lz. Some suggest that while a complete set of commuting observables exists, not all eigenstates of L^2 must correspond to eigenstates of Lz.
The discussion is active, with various interpretations being explored. Some participants provide insights into the mathematical framework, while others question the assumptions regarding eigenstates and their relationships. There is no explicit consensus, but several productive lines of reasoning have been presented.
Participants note the complexities introduced by degenerate eigenvalues and the potential for linear combinations of eigenstates to affect the eigenstate relationships. The specific context of orbital angular momentum operators is also mentioned, indicating a nuanced understanding of the topic.
Henk
I was wondering: is every eigenstate of L^2 also an eigenstate of Lz?
I know that commuting operators have the same eigenfunctions but if [A,B] = 0 and a is a degenerate eigenfunction of A the the corresponding eigenfunctions of A are not always eigenfunctions of B.
Not necessarily. What [A,B]=0 means (for hermitian operators) is that there EXISTS a basis of eigenvectors common to A and B.
If A|a>=a|a> and a is a nondegenerate eigenvalue of A, then |a> is also an eigenvector of B (this is easy to prove). If a is degenerate, then you can find an orthonormal basis in the eigenspace of a consisting of eigenvectors common to A and B.
So not every eigenstate of L^2 is an eigenstate of Lz.
You can make it a nice discussion in the following way.
[tex]\hat{J}^{2} ,\hat{J}_{3}[/tex]
form a complete system of commuting observables.It's not difficult to show that.
Therefore,a spectral pair [itex]\left(\hbar^{2} j(j+1), \hbar m_{j}\right)[/itex] determine,up to a phase factor,a vector from the irreducible space of the irreducible finite dimensional linear representation of the angular momentum algebra* (which is isomorphic to [itex]su(2)[/itex] which is isomorphic to [itex]so(3)[/itex]).This is an eigenvector to both operators.
*One can prove that an eigensubspace of [itex]\hat{J}^{2}[/itex] associated to the nondegenerate spectral value [itex]\hbar^{2} j(j+1)[/itex] is invariant to the action of all the linops of the representation of the ang.mom.algebra and does not admit any nontrivial invariant subspaces,therefore it is a subspace of an irred.representation of the ang.mom.algebra.
So all eigenstates of [itex]\hat{J}^{2}[/itex] are eigenstates of [itex]\hat{J}_{3}[/itex] in the simple case of uniparticle systems.
Daniel.
P.S.For the particular case of orbital ang.mom.ops,the things are a bit easier,as one has the particular realization [itex]\mathcal{H}=L^{2}\left(\mathbb{R}^{3}\right)[/itex] and the basis from spherical harmonics.
Since [tex]L_z[/tex] does not commute with any other [tex]L_u[/tex] for [tex]\hat{u}[/tex] any other direction not parallel or antiparallel to [tex]\hat{z}[/tex], it should be clear that it's pretty easy to arrange for an eigenstate of [tex]L_u[/tex] and [tex]L^2[/tex] to not be an eigenstate of [tex]L_z[/tex].
In addition, the reverse is also possible. That is, there are eigenstates of [tex]L_z[/tex] that are not eigenstates of [tex]L^2[/tex]. To make one, just take two eigenstates of both [tex]L^2[/tex] and [tex]L_z[/tex] that happen to have the same [tex]L_z[/tex] eigenvalue but different [tex]L^2[/tex] eigenvalues, and mix em up.
Carl
I have no idea why i didn't think of linear combinations of eigenstates.:rolleyes:
Daniel.
  • · Replies 23 ·
  • · Replies 31 ·
