What kinds of engineers usually build submarine?
  • Thread starter Thread starter redgoat
    Build Submarine
The discussion revolves around the types of engineers involved in the construction of submarines, exploring various engineering disciplines and their roles in submarine design and construction. It includes considerations of different types of submarines and the complexity of their systems.
  • Some participants suggest that a wide range of engineers, including electrical engineers (EE) and mechanical engineers (ME), are involved in submarine construction, with a significant portion of the work attributed to these fields.
  • Others emphasize the complexity of submarines, noting that various specialists, such as nuclear engineers, thermodynamicists, and hydrodynamic specialists, contribute to different subsystems.
  • A participant points out that the type of submarine in question significantly influences the engineering disciplines involved, suggesting that military submarines require more diverse expertise compared to smaller or tourist submarines.
  • There is mention of the importance of tradespeople, such as welders and electricians, in the actual construction process, highlighting the collaborative nature of submarine building.
  • Some participants propose that aspiring engineers should consider structural or mechanical engineering as a starting point, depending on their interests in hull design or machinery systems.
  • Discussion includes the use of modern design techniques, such as AutoCAD and virtual reality (V/R), in the engineering process for submarines.
Participants generally agree that multiple types of engineers are involved in submarine construction, but there is no consensus on the specific roles or the extent of involvement of different engineering disciplines. The discussion remains unresolved regarding the exact contributions of various fields based on the type of submarine.
The discussion highlights the dependence on the type of submarine being referenced, which may affect the engineering disciplines involved. There are also indications of variability in roles based on project needs and personnel availability.
redgoat
Wet ones..
What kind of submarine?
Sorry, but that had to be done. A sub is such an incredibly complex conglomeration of components that no dozen areas of expertise could put one together. The actual construction is done by incredibly talented welders, millwrights, electricians, electronics technologists, painters and so on. Every subsystem on board is designed by specialists in a particular field. Nuclear engineers and thermodynamicists and steam engineers and bearing specialists design the power train; accoustic and electronic engineers design passive and active sonar systems; hydrodynamic specialists design propellors and manouevring thrusters; weapons technologists handle torpedoes, decoys, mines, deck guns, etc.; medical specialists design the sickbay; everything down to galley layouts and janitorial facilities are set up by people who know that particular area. The easiest answer to "who builds it" is a navy.
The simple answer (as Danger implied) is every kind.
I think the question should hing on the type of sub in question. Yeah, the USS Parche needed every type of engineer imaginable; however, the glass bottom subs tourists ride in Wikiki probably were designed by only a few engineers. To answer the original question we need to know the scale of the question and not just assume the asker meant trafalgar class submarines.
Being in the business, I would say that the brunt of the engineering is done by EE's and ME's (85%). In a lot of cases it comes down to who is available to work the project. We need someone to work on designing a "X" and although you have never designed an "X" before, you have been picked to do the work. Granted there are people who have spent a lifetime working RF or sonar but in todays do more with less Navy, you get called on to do a variety of work, it's what makes the job interesting. I am speaking only on the design side of the house, test and evaluation, building the hull, etc. brings in the tradesmen, techs, etc.
If you are asking because you are interested in that kind of career, then I would say Mechanical or structural Engineering would be a good point of departure to enter the field. Structural if hull design is what you are after, or mechanical if the workings of the machinery (life support, propulsion, cooling, heating, etc.)
Artman is correct, structural/mechanical for hull and machinery design. I would look at learning AutoCAD, most if not all builders are doing the arrangements of equipment using modeling. The Virginia Class subs were designed using V/R techniques. You could expect to be designing anything from hull penetrators to machinery mounts to enclosures for equipment. If you are looking at an EE degree, there are many different avenues you could go. RF or antenna design, acoustics, DSP and computer control... the list goes on and on. I would caution that most of us have had our hands in more than one of these areas, so expect to cross over to mechanical even if you are an EE. I work in electromagnetic compatibility but in doing so have been involved in cabinet design, connector design, you get the drift.
  • · Replies 59 ·
