Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Topology & Geometry
Reply
image Orientable Manifold with Boundary Share It Thread Tools Search this Thread image
Old Jul5-05, 03:42 AM                  #1
kakarukeys
kakarukeys is Offline:
Unhappy Orientable Manifold with Boundary
How does the orientation on M induce an orientation on the boundary of M?
I follow the book Lectures on Differential Geometry by Chern, do not understand the proof.
The proof is
the Jacobian Matrix of the transformation between coordinates of two charts has positive determinant (oriented charts), so the smaller Jacobian Matrix with one row and one column deleted (corresponding to the only one coordinate axis that runs away from the boundary) has positive determinant.
Please do me a favour by explaining the proof clearly, or give me another easier proof.
Old Jul5-05, 07:26 AM                  #2
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Hrm.
I would have said "Because it does in Euclidean space", but I don't know how easy it is to prove you can patch together orientations of the pieces of the boundary when it spans multiple charts.
Old Jul5-05, 01:10 PM                  #3
mathwonk
mathwonk's Avatar
mathwonk is Offline:
Recognitions:
Homework Helper Homework Helper
how does counter clockwise orientation on the upper half plne induce an orientation on the real line?
by noticing that at a point of the real line, one can distinguish between an arrow pointing into the upper half plane and one pointing out of it.
so a vector v along the x axis is oriented positively if, when it is supplemented by an arrow w pointing into the upper half plane, we get an oriented (counterclockwise) basis <v,w> for the (tangent space to the) upper half plane.
Old Jul5-05, 01:11 PM                  #4
mathwonk
mathwonk's Avatar
Recognitions:
oh, that is the euliden space acse. but an oriented manifold is by definition one that admits an orientation preserving atlas, so those charts do preserve the euclidean orientation.
Old Jul6-05, 12:11 AM       Last edited by kakarukeys; Jul6-05 at 12:15 AM..            #5
kakarukeys
Hrm.
Suppose we have charts that cover regions not containing the boundary and charts that cover regions containing the boundary. They are oriented (coordinate transformations among them have positive-determinant Jacobian matrix).
for a region D, let LaTeX Code: {u^1, u^2, ...., u^m} be the coordinates, suppose LaTeX Code: u^m = 0 is the boundary.
Let LaTeX Code: du^1 \\wedge du^2 \\wedge ... \\wedge du^m be the positive orientation.
then since LaTeX Code: du^1 \\wedge du^2 \\wedge ... \\wedge du^{m-1} is non-zero and gives an orientation on the boundary contained in region D. Minus sign gives another orientation.
if we can transform to other charts on boundary, preserving the orientation, we can extend the orientation to the entire boundary.
And thus we need to show
LaTeX Code: \\frac{\\partial (v^1, ..., v^m)}{\\partial (u^1, ..., u^m)} > 0
implies
LaTeX Code: \\frac{\\partial (v^1, ..., v^{m-1})}{\\partial (u^1, ..., u^{m-1})} > 0
I don't understand the proof of the above in the book, anyone has any idea?
I can type the proof out, if you want.
Old Jul6-05, 01:27 AM                  #6
mathwonk
mathwonk's Avatar
Recognitions:
did my comments mean nothing at all?
Old Jul6-05, 01:28 AM                  #7
mathwonk
mathwonk's Avatar
Recognitions:
another suggestion: just ebcause chern is a great mathematiciazn does not mean he writes learnable boks. read guillemin and pollack instead. or my notes. i will send them to you if you give me an address.
Old Jul6-05, 03:27 AM                  #8
kakarukeys
Yes your comments explained the basic idea behind the proof.
I am still struggling with the steps of the proof.
Old Jul6-05, 05:43 AM                  #9
kakarukeys
ya sure. If you have notes, please send to me
kakarukeys@gmail.com
thank you.
Old Jul6-05, 01:06 PM       Last edited by mathwonk; Jul6-05 at 03:35 PM..            #10
mathwonk
mathwonk's Avatar
Recognitions:
the point is that if you have an n-1 dimensional subspace spanned by the first n-1 vectors in a basis, and then the last vector points in a giuven direction, if you choose another such absis, the change of basis matrix will be in 2 blocks.
there will be an n-1 by n-1 block in the upper left corner say, and a positive number in the lower right corner, and all zeroes otherwise in the last row and last column.
hence the determinant of the whole matrix being positive forces also the determinant of the upper left block to be positive also.
but i warn you, chern's writings are the worlds most terse and merciless. they are also non conceptual and highly compoutational. he was a great great mathematician but i do not recommend his works to anyone as the sole source for learning any subject at all.
here is a review by another outstanding mathematician:
""This excellent and polished book may not be suitable for the very beginning student, but it is highly recommended for all mathematicians, from the advanced undergraduate student to the experienced professor. For many mathematicians it will be a work of reference for their research. It will be welcome by physicists."
Prof. F Hirzebruch
Max-Planck Institute, Bonn"
Old Jul6-05, 01:10 PM                  #11
mathwonk
mathwonk's Avatar
Recognitions:
i will try to pdf my notes and make them sendable. but they are just a rewrite of the treatment in guillemin and pollack which may be in your library.
Old Jul6-05, 11:53 PM                  #12
mathwonk
mathwonk's Avatar
Recognitions:
did i answer your question? (about the matrices) in the first half of post 10?
Old Jul8-05, 05:59 AM                  #13
kakarukeys
Please don't if it is too laborious, I don't want to waste your precious time.
In my case, I only have
LaTeX Code: \\frac{\\partial v^m}{\\partial u^m} > 0
There may not be zeroes in the last row and last column.
Old Jul8-05, 10:17 AM                  #14
mathwonk
mathwonk's Avatar
Recognitions:
well if you think about the definition of a matrix of a linear transformation, the last row is hte image of the last vector, expanded in terms of the basis ofm the target space.
now we have chsoen both bases to end with a vector pointing into the manifold, so i guess al i can say is that the last entry of the last comloumn is positive, since the component of an inner pointing vector is a positive multiple of another inner pointing vector.
but if you look at the previous columns, you are expanding the images of the basis vectors for the boundaryu space, in terms of anmother absis for that same subspace. so there is no need to use the last inner pointing vector in that expansion. so every columnh except the last has a zero in the last entry.
thus the last row is all zeroes except for the alst right bottom corner. then the same argument applies. i.e. the determinant is positive iff the determinant of the upper left block is positive. how about that?
Old Jul10-05, 02:10 AM       Last edited by kakarukeys; Jul10-05 at 02:18 AM..            #15
kakarukeys
your argument is sound unless the following is true.
a cotagent space at a point on the boundary is a direct sum of the cotagent space of that point when the boundary is considered an independent manifold and its complement.
Every first m - 1 basis vectors given by any chart span the first subspace, and the last vector pointing into the manifold always spans the other subspace.
I think it's true by definition of the chart. or is it true?
Old Jul10-05, 02:20 AM                  #16
kakarukeys
only then can it be that
when we transform from u basis to v basis,
the first m-1 vectors are shuffled.
and the last vector is only multiplied by a constant.
image image
Reply
Thread Tools
Similar Threads for: Orientable Manifold with Boundary
Thread Thread Starter Forum Replies Last Post
Parallelizable Manifold amd939 Topology & Geometry 3 Nov6-07 08:56 PM
a smooth manifold bigli Calculus & Beyond 6 Jul5-07 08:40 AM
O(3) a 3-manifold in R^9 dtkyi Calculus & Analysis 4 May8-07 06:13 PM
Hybrid Manifold Zitterbewegung Beyond the Standard Model 0 Jun8-06 05:01 AM
expanding manifold with constant boundary Mike2 Topology & Geometry 8 Apr14-04 05:55 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
