Solving this differential equation
The discussion revolves around solving a differential equation derived from a mechanics problem in polar coordinates, specifically the equation involving the second derivative of phi equal to (-g/R) sin phi. Participants explore the challenges of integrating this equation to find phi as a function of time, with references to elliptic functions and numerical methods.
  • One participant questions why the differential equation cannot be integrated directly to find phi(t), leading to a discussion on the nature of the equation.
  • Another participant explains that direct integration is not feasible and outlines a method to set up the elliptic integral, suggesting that the equation leads to an integral that is recognized as an elliptic integral.
  • A later reply emphasizes the distinction between integrating with respect to time versus the variable phi, indicating a misunderstanding in the integration approach.
  • Another participant suggests using a Taylor expansion as a potential method for approximation.
  • One participant recommends numerical analysis as a viable approach to solving the equation.
The discussion reflects multiple competing views on how to approach the solution of the differential equation, with no consensus on a single method being established. Participants express uncertainty about the integration process and the applicability of various mathematical techniques.
Participants reference the limitations of elementary functions in solving the equation and the potential need for approximations or numerical methods, but do not resolve the mathematical steps involved in the integration process.
Moneer81
Hello,
while working on a simple mechanics problem using polar coordinates, I got this equation
second derivative of phi = (-g/R) sin phi
now I need to solve this to get an equation for phi (t) but the books says that I cannot solve this using elementary functions and that the solution will be the more complex Jacobi elliptic function. My question is why can't I integrate twice to get the equation for phi (t) ?
thanks a lot
You can't just straight integrate that differential equation. I'm not even sure how one would attempt it. Here's one way to set up the elliptic integral:
Multiply through by [tex]\dot{\phi}[/tex] and get the differential equation
[tex]\ddot{\phi} \dot{\phi} = -g/R \dot{\phi} sin \phi[/tex]
which we recognize as being the first time derivative of
[tex]\dot{\phi}^2 = g/R cos \phi + C[/tex]
when then leads to the integral:
[tex]\int d\phi ~ 1/\sqrt{g/R cos \phi + C} = t - t_0[/tex]
which is then the elliptic integral left behind. This is why we make things like the small angle approximation, where applicable. If you're working with exact numbers, you could pretty simply write a numerical algorithm
MalleusScientiarum ,
why can't we straight integrate it with respect to time ?
ok never mind...stupid question. i know why :)
Yeah - because it's sine of phi, not sine of t.
In post #2, you missed a little "2" when going from [itex]\dot{\phi}\ddot{\phi}[/itex] to the square of the first derivative.
Daniel.
i guess theylor expansion is the best choice
I advise numerical analysis.
