What Forces Cause Liquid to Rise in a Centrifuge?
  • Context: Undergrad
  • Thread starter Thread starter Seatl
    Centrifuge Liquid
The discussion revolves around the forces that cause liquid to rise in a centrifuge, focusing on the underlying mechanics and factors influencing the behavior of the liquid during rotation. Participants explore theoretical explanations and practical considerations related to the experiment.
  • One participant describes their observation that increased angular velocity forces the liquid outward and upward in the centrifuge, seeking clarification on the forces at play.
  • Another participant prompts for a list of all forces acting on the liquid and questions whether a rotating frame of reference is being used.
  • Factors affecting the height of the liquid, such as viscosity and the gravitational/atmospheric environment, are suggested by a participant.
  • Inertia is identified by some participants as a key factor, with the liquid attempting to move in a straight line while being forced into circular motion.
  • A participant explains that the centrifugal force pushes the fluid outward, balancing with an increase in liquid height to maintain atmospheric pressure at the free surface.
  • Another participant discusses the interaction between the viscous fluid and the rotating test tube, emphasizing the role of forces exerted at angles and the rigidity of the structure.
Participants express various viewpoints on the forces involved and the factors affecting liquid behavior in a centrifuge. There is no clear consensus, as different explanations and models are presented without resolution.
Some discussions involve assumptions about the system's behavior, such as the role of viscous forces and the nature of pressure distribution, which remain unresolved.
Seatl
Hey,
As part of an investigation, I constructed a basic centrifuge consisting of a fast rotating beaker filled with liquid.
I have observed that an increased angular velocity forces the liquid out of the centre and further up the sides of the centrifuge, as expected. However, I am having difficultly explaining exactly why this happens in terms of the forces acting of the liquid. Could anyone help?
In addition, could anyone suggest what other factors other than speed of rotation might affect the height obtained by the liquid?
Thanks
Can you list all of the forces that are acting on the liquid? A common issue is that people forget a force. Also, are you using a rotating frame of reference or not?
Thanks
The first two that come to mind are the viscosity of the liquid and the gravitaional/atmospheric environment in which the experiment is conducted.
The simplest part of the explanation is inertia. The liquid is trying to move in a straight line. Since it is being forced to move in a circle, there is a component of its direction vector moving it outward in the centrifuge.
Seatl said:
Hey,
Thanks
The whole amount of fluid is rotating as a rigid solid at an angular speed [tex]\omega[/tex]. The free surfaces is characteristically curved like a parabola.
Danger, viscous forces are ultimately the responsible of communicating the movement of the beaker to fluid. Once the steady regimen is reached, such forces don't play any role.
The centrifugal force pushes fluid outwards the centre of rotation. Such pushing is balanced with an increasing of liquid height, because static pressure on the free surface must remain being the atmospheric one. As it is not an hydrostatic system, the pressure is not given by liquid height, but by an appropriate arrangement of both hydrostatic and centrifugal terms. External zones are zones of great pressure, and so they will need a greater liquid column in order to reach the same atmospheric pressure on the free surface.
Gosh, If I got that question on a test I would have gave response along the lines of
Say the viscous fluid was in a test tube and the test tube is being rotated. Then the entire solid will attempt remain inact or rigid. For example if the bottom half of the test tube has force exerted on it at an angle, then it will exert a pulling force it's upper half so then it moves with the lower half, it is a rigid structure. When rotating, the force is always exerted at an angle which could be put into the vectors of tangential acceleration and revolutional accelerational. In this case there isn't opposite force to pull the viscous fluid back downward, as with the test tube due to its rigidity, although the test tube still exerts a force on the fluid at an angle with its x and y components. Therefore the viscous fluid will continue being being pushed upward by the y component of the force.
or something like. I think this is what mathman was saying, hope a response with that basic idea wouldn't have been wrong.
What he said
End
Thanks all, that's perfect
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 35 ·
