Does the exponent in a series affect its radius of convergence?
The discussion revolves around the radius of convergence of the series \(\sum_{k=0}^\infty \frac{(n!)^3z^{3n}}{(3n)!}\) and how the exponent in the series affects this radius. Participants explore the implications of the term \(z^{3n}\) compared to \(z^n\), considering both theoretical and mathematical reasoning.
  • One participant questions whether the index of summation is \(k\) or \(n\), which could affect the interpretation of the series.
  • Another participant applies the ratio test to find the limit and concludes that the radius of convergence is 3, based on their calculations.
  • A different participant agrees with the result obtained using the ratio test but expresses confusion regarding the initial claim of a radius of convergence of 0 for \(z^n\).
  • One participant suggests that the only difference between \(z^{3n}\) and \(z^n\) is the presence of \(z^3\) in the final formula, implying a transformation of variables could clarify the situation.
  • Another participant challenges the assertion that the radius of convergence would be 0 for \(z^n\), referencing Euler's work to argue that it would actually yield a radius of 3 when considering the cube root.
Participants do not reach a consensus on the implications of the exponent in the series. There are competing views regarding the radius of convergence and the interpretation of the series terms, leading to unresolved questions about the index of summation and the correctness of earlier claims.
There are unresolved assumptions regarding the definitions of the series terms and the implications of changing the exponent. The discussion reflects differing interpretations of the radius of convergence based on the series structure.
ModernLogic
Hi folks. I need to find the radius of convergence of this series: [tex]\sum_{k=0}^\infty \frac{(n!)^3z^{3n}}{(3n)!}[/tex]
The thing throwing me off is the [tex]z^{3n}[/tex]. If the series was [tex]\sum_{k=0}^\infty \frac{(n!)^3z^n}{(3n)!}[/tex] I can show it has radius of convergence of zero. But [tex]z^{3n}[/tex] means its only taking power multiples of 3. Does that change anything?
Thanks.
is the index of summation k or n?
The problem can still be solved using the ratio test:
[tex]\lim_{n\rightarrow\infty}\frac{((n+1)!)^3z^{3n+3}}{(3n+3)!}\times\frac{(n!)^3}{z^{3n}(3n)!}[/tex]
=[tex]\lim_{n\rightarrow\infty}\frac{(n+1)^3z^{3}}{(3n+3)(3n+2)(3n+1)}[/tex]
Now, being sloppy so that I don't have to write so much, in the limit this is going to be equal to:
[tex]\lim_{n\rightarrow\infty}\frac{(n)^3z^{3}}{27(n)^3}[/tex]
=[tex]\lim_{n\rightarrow\infty}\frac{z^{3}}{27}[/tex]
=[tex]\frac{z^{3}}{27}[/tex]
so, requiring the absolute value of this expression to be less than 1 gives a radius of 3
I got the exact same result, Leonhard, through D' Alambert's Criterium (ratio test), but given he said a radius of convergence of 0 for z^n, it confused me to what is exactly the index of summation k or n.
Yeah, I didn't even catch that, but its probably just a mistake.
Modern Logic: The only difference between having z3n instead of zn in the problem is that you will have z3 instead of z in the final formula- Take the cube root. (Let y= z3 so that the sum involves yn.)
However, you are wrong when you say that if the problem involved zn instead of z3n you would get a radius of convergence of 0. As Leonard Euler said, you would get 27 and so for z, the cube root of that, 3.
