Write an expression for the Optical path length
The discussion focuses on calculating the Optical Path Length (OPL) for rays passing through a converging lens with a refractive index of 1.355. The user presents two expressions for OPL: one for a ray passing through the edge of the lens and another for a ray passing through the center. The calculations reveal a discrepancy in determining the image distance 'x', prompting a clarification on the squaring of sums in the equations. The correct approach emphasizes the importance of applying the binomial expansion when squaring sums.
  • Understanding of optical physics, specifically lens behavior
  • Familiarity with the concept of Optical Path Length (OPL)
  • Knowledge of the Pythagorean theorem
  • Basic algebra skills for manipulating equations
  • Study the principles of ray optics and lens equations
  • Learn about the binomial theorem and its application in physics
  • Explore the concept of refractive index and its impact on light propagation
  • Practice solving problems involving Optical Path Length in various lens configurations
Students and professionals in optics, physics educators, and anyone involved in optical engineering or lens design.
goodo
Hi,
I'm hoping I can get some help. (I'm a first time poster, so if there's something that isn't quite clear, please let me know).
A converging lens (n=1.355) in air has diameter 4.0cm, thickness 0.50cm and zero thickness at its edges.
A point object at 'So' = 18cm has an image at 'Si'= x cm. (where 'So' and 'Si' are distances from the center of the lens)
(a) Write an expression for the Optical path length (OPL) of the ray passing through the edge of the lens and (b) an expression for the OPL of the ray passing through the centre of the lens, and (c) determine the distance x.
(sqrt= square root, sq = squared) For (a) I used pythagorus. OPL = sqrt(18 sq + 2 sq) + sqrt(x sq + 2 sq)
(b) OPL = 17.75 +(x-0.25) + 0.5n
=17.5+x+.6775
=18.1775+x
=18.18+x
(c) Now I have both in term of x. Since OPL1=OPL2,
sqrt(18 sq + 2 sq) + sqrt(x sq + 2 sq)=18.18+x
(square both sides) 18 sq + 4 + x sq + 4 = 18.18 sq + x sq
332 + x sq = 330.5 + x sq
I can't think of any other way to do it, yet something must be wrong as I have to calculate x. Is there a reason why I'm 1.5 off other than rounding? Wouldn't the x sq both cancel out leaving me with nothing?
Thanks
goodo
Welcome goodo,
I think everything's OK up to here:
The square of a sum is not the sum of squares.
Remember: (a + b)2 = a2 + 2ab + b2.
BTW, the 1st root has no x, so you can calculate its value. Makes things easier...
Thansk for your response arcnets.
