What is the Calculation for Finding Gear Ratio in a Multi-Gear System?
  • Thread starter Thread starter TSN79
    Motor Rpm
The calculation for finding gear ratios in a multi-gear system involves determining the number of teeth and mid tooth-diameter for each gear based on the motor speed and desired output speed. In this case, a motor operates at 1450 rpm, and the final gear must run at 80 rpm, resulting in a gear ratio of 18.125. The first gear has a mid tooth-diameter of 95 mm and a gear module of 5 mm, leading to 19 teeth. The square root of the gear ratio, approximately 4.26, is used to calculate the number of teeth on the second gear, resulting in 81 teeth.
  • Understanding of gear ratios and their calculations
  • Familiarity with gear modules and tooth diameters
  • Basic knowledge of rotational speed (rpm) and its implications
  • Ability to perform algebraic calculations involving square roots
  • Research the principles of gear ratio calculations in mechanical systems
  • Learn about the relationship between gear modules and tooth counts
  • Explore the impact of gear diameter on system design and constraints
  • Study the application of gear trains in various mechanical devices
Mechanical engineers, students studying mechanical systems, and anyone involved in designing or analyzing gear mechanisms will benefit from this discussion.
TSN79
A motor runs at 1450 rpm. Attached is a gear that has a gear module of 5 mm, and a mid tooth-diameter of 95 mm. This wheel is toothed up with a second wheel who's shaft drives a third wheel. This third wheel is then toothed up with the fourth and last wheel who's shaft runs let's say dryer, which is supposed to run at 80 rpm. This last gear has a module of 8 mm. The last gear's diameter must be less than 700 mm 'cause of space. I'm supposed to find the number of teeth and the mid tooth-diameter for each gear. Here what my book does to begin with:
The ratio is calculated as
[tex]\frac{1450}{80}=18,125[/tex]
[tex]z_1=\frac{d_1}{m_1}=\frac{95}{5}=19[/tex] (the number of teeth on the first gear)
Now my book does something I don't get. It finds:
[tex]\sqrt{18,125}=4,26[/tex]
This number is then used to find the number of teeth on the second wheel:
[tex]U=\frac{z_2}{z_1} \Rightarrow z_2=U\cdot z_1=4,26 \cdot 19=81[/tex]
As I said earlier, I can't see why the square root of the ratio is calculated...
Obviously the diameter of the first gear is 95 mm. Is there anything else you have failed to mention? How about writing out the entire problem so we know exactly what we have to deal with?
I've updated the problem above to include the whole thing now...
24K
