How Do You Solve Accelerated Linear Motion Problems in Physics?
The discussion revolves around problems related to accelerated linear motion in physics, specifically focusing on a particle's motion with constant acceleration and the motion of balls thrown by a juggler. Participants are exploring the relationships between speed, time, and height in these contexts.
  • Mixed
  • Participants discuss the use of kinematic equations to relate initial velocity, acceleration, and time. There is an emphasis on understanding the motion of the juggler's balls and the calculations required to determine initial velocity and timing.
Some participants have provided insights into the equations of motion and suggested approaches for solving the juggler's problem. There is recognition of the complexity of the questions, particularly regarding the timing and heights of the balls during their motion.
Participants are navigating multiple parts of the problem, with some expressing confusion about where to begin, particularly with the juggler's scenario. The discussion reflects a need for clarification on the relationships between the different variables involved.
mcintyre_ie
Hey
Im having some trouble with this Accelerated Linear Motion question. I don't have any clue where i should even start with part (B).
(A) A particle moving in a straight line with constant acceleration passes three points, p, q and r and has speeds u and 7u and p and r respecitively.
(I) Find its speed at q, the midpoint of pr, in terms o u
(II)Show that the time from p to q is twice that from q to r
(B) A juggler throws up six balls, one after the other at equal intervals of time t, each to a height of 3m. The first ball returns to his hand t seconds after the sixth was thrown up and is immediately thrown to the same height, and so on continually. You may assume that each ball moves vertically.
Find:
(i) the initial velocity of each ball
(ii) the time t
(iii) the heights of the other balls when anyone reaches the jugglers hand.
Im just lost, don't have a clue where to start. My head just starts to go into overload when i even think about it. Please help!
Your formula
V(final) = V (original) + acceleration * time
or
Vf - Vo + at
You have only 3 points but 4 velocities, so I assume, your original or initial velocity would be u.
Have you tried this formula?
Nautica
Yes, I've used the formulae before, I am having trouble with part two, the juggler question.
Part two is relatively simple.
Each ball has acceleration -g= -9.81 m/s2. If we take "v" to be the initial velocity of each ball, then v(T)= v- 9.81T in m/s where T is measured in seconds since the ball was thrown.
In addition, the height of each ball after T seconds is given by
h(T)= vT- (9.81/2)T2.
The ball will continue upward until its velocity is 0: v- 9.81T= 0 so
T= v/9.81. We are told that the height at that time is 3 m:
v(v/9.81)- (9.81/2)(v/9.81)2= v2/(2*9.81)= 3 so
v2= 2*3*9.81 and v= &radi;(2*3*9.81).
You can find t in either of two ways: directly- The ball comes back to the person's had (assumed same height) exactly t seconds after the sixth ball is throne up and there is and interval of t seconds between each one: the first ball comes back to the person's had after 6t seconds: h(6t)= v(6t)- (9.81/2)(6t)2= 0. You know v from the previous problem. Solve for t.
Less directly: because of the symmetry of the motion, each ball attains it highest point exactly half way through its motion: 3t.
Since you calculated that time, T, in the first problem, 3t= T. Solve for t.
You know that when the first ball is again in the juggler's hand, time 6t has passed. Its height is0. The second ball is exactly "t" behind. Its height will be given by h(5t), the third ball's height will be h(4t), the fourth ball's height by h(3t), the fifth ball's height by h(2t), and the sixth ball's height by h(t). If the juggler throws the first ball up again the instant he catches it, each ball will have one of those 6 heights each time a ball is caught.
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 21 ·
