Find energy dissipated due to air friction in a thrown ball
The energy dissipated due to air friction for a 0.40 kg ball thrown vertically upward at 30 m/s, reaching a height of 40 m, is calculated to be 284.8 J. The force of air friction is determined using the formula F = 0.5 * Cd * rho * A * v^2, where Cd is the drag coefficient (0.47), rho is the air density (1.2 kg/m^3), A is the cross-sectional area (calculated as 4 * π * (0.20 m)^2), and v is the velocity (30 m/s). The work done by air friction, W = Fd, is negative, indicating energy loss due to friction.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of potential energy and work
  • Knowledge of fluid dynamics, specifically drag force calculations
  • Basic geometry for calculating the cross-sectional area of a sphere
  • Study the derivation and application of the drag force formula in fluid dynamics
  • Learn how to calculate potential energy and kinetic energy in projectile motion
  • Explore the effects of varying coefficients of drag on different shapes
  • Investigate the relationship between air density and altitude for more accurate calculations
Physics students, engineers, and anyone interested in understanding the dynamics of projectile motion and energy dissipation due to air resistance.
Gashouse
A 0.40 kg ball is thrown vertically upward with a speed of 30 m/s. The ball reaches a height of 40 m. Assuming g= 9.8 m/s^2, the energy dissipated due to air friction is :
F=mgh m=0.40kg, g=10 m/s^2, h=40m, a= 30 m/s
Not sure if I set this problem up right, and since everything is given don't know how to find energy dissipated due to friction.
Can you calculate the initial energy of the ball, and the energy it has when it reaches the highest point?
F is not mgh. mgh is potential energy.
30 m/s is not acceleration, it is the initial velocity.
To calculate the energy dissipated due to air friction, we need to first calculate the work done by the force of air friction. The work done by a force is given by the formula W = Fd, where F is the force and d is the displacement.
In this case, the force of air friction is opposing the motion of the ball, so it is acting in the opposite direction of the displacement. Therefore, we need to use the negative value of the force of air friction in our calculation.
The force of air friction can be calculated using the formula F = 0.5*Cd*rho*A*v^2, where Cd is the coefficient of drag, rho is the air density, A is the cross-sectional area of the ball, and v is the velocity of the ball.
Since we are assuming that the ball is a perfect sphere, we can use the formula for the cross-sectional area of a sphere, which is A = 4*pi*r^2, where r is the radius of the ball.
The coefficient of drag for a smooth sphere is approximately 0.47, and the air density at sea level is approximately 1.2 kg/m^3.
Plugging in all the values, we get F = 0.5*0.47*1.2*4*pi*(0.20)^2*(30)^2 = 7.12 N
Now, we can calculate the work done by this force using the formula W = Fd. Since the ball is moving vertically, the displacement is equal to the height it reaches, which is 40 m.
Therefore, W = (-7.12 N)*(40 m) = -284.8 J
Since the work done by the force of air friction is negative, it means that the energy is being dissipated or lost. Therefore, the energy dissipated due to air friction in this case would be 284.8 J.
  • · Replies 32 ·
  • · Replies 38 ·
14K
