Solving a Physics Problem: Accelerating Plane
  • Thread starter Thread starter huskydc
    Plane
The discussion revolves around a physics problem involving an inclined plane that is accelerating. The scenario includes a block resting on the plane, with specific parameters such as the angle of inclination, mass of the block, and coefficient of static friction. The objective is to determine the minimum acceleration required for the block to slide down the plane.
  • Participants discuss applying Newton's 2nd Law to find the acceleration. There are attempts to set up equations based on forces acting on the block and the inclined plane. Some participants express frustration over their attempts to solve for acceleration, indicating a struggle with the mathematical setup.
The discussion is ongoing, with participants sharing their equations and approaches. There is no clear consensus on the correct method or solution yet, but some guidance has been offered regarding the coordinate system to use.
Participants are working under the constraints of the problem as stated, including the specific values for mass, angle, and friction. There is an indication of confusion or difficulty in applying the concepts correctly, which may be affecting their ability to arrive at a solution.
huskydc
this is another post, but i just want to post it in this room and see if ANYONE knows how to solve this:
I've tried everything, now I'm getting depererate
An inclined plane that makes an angle of 28° to the horizontal is mounted on wheels. A small block of mass m = 1.2 kg rests on the plane, held there by a coefficient of static friction µ = 0.73.
The plane is accelerating to the right. What is the minimum acceleration in order that the block slides down the plane?
Any help would be great !
Apply Newton's 2nd Law and solve for a.
The 0 degrees with the horizontal system of coordinates will be the easier one.
i tried literally everything, would anyone please help me solve it? lol...
i came up with the following, after lots of equation, i used it to solve for a, didn't work either
g sin (theta) - mu (a sin (theta) + g cos (theta) ) = a cos (theta)
Well, with the coordinate system set as i said above.
[tex]\sum F_{x} = ma = - n \sin \theta + F_{f} \cos \theta[/tex]
[tex]\sum F_{y} = 0 = F_{friction} \sin \theta + n \cos \theta - mg[/tex]
  • · Replies 27 ·
  • · Replies 68 ·
14K
