| Thread Closed |
A power plant that uses more power than it generates |
Share Thread | Thread Tools |
| Jul16-05, 05:46 PM | #1 |
A power plant that uses more power than it generatestry googleing Yards Creek Power Plant what a waste of power..!!! |
| Jul16-05, 05:51 PM | #2 |
Well, the alternatives are:
(1) Have brownouts during the day, because power plants aren't producing enough power to meet demand. (2) Waste gobs of power at night, because power plants are producing far more than is consumed. |
| Jul16-05, 05:52 PM | #3 |
Niagra falls does the same thing at night time. As it pumps it up hill, it turns the generators in reverse to make power. During the day, it falls back down, and turns the generators once more to meet peak demands. Electric Generators can only produce so much power druing the day, and if the demands are not high, it only makes sense to use this power that would other wise be wasted to give the water a higher potential energy.
| Jul17-05, 06:19 AM | #4 |
There's a similar system in Llanberis in Wales, - the "Electric Mountain" at Dinorwig. At the time (1985?), it was the largest civil engineering project ever accomplished in the UK, which isn't surprising if you've seen the inside of the generator hall; it's massive, and is actually inside a mountain. You can go on a tour of the facility, it's fantastic.
| Jul17-05, 08:15 AM | #5 |
i) meeting peak demands. ii) Pumping Reactive Energy into the electrical system. Usually such turbines are coupled to a synchronous (did I write it right??) motor-generator. These motors are capable of generating Reactive Energy when they works with an appropriate intensity in the rotor. Electrical companies must balance the consumption of Reactive Energy, because this energy is employed by motor consumers to magnetize the machines during the day. Also, insuflating Reactive Energy will stabilize and increase the voltage in some disfavoured electrical node. You know also that an excessive consumption of Reactive Energy is penalized by electrical companies, because it is a more expensive type of energy. So it seems these power plants give more profits to electrical companies than we might think, by the way they wouldn't exist if this last statement is not completely true. Have I translated rightly the term "Reactive Energy"? I am not sure I did it. I don't know if this power is called so in english. Anyway, if some electrical engineer is not agree with me, feel free to criticise me (but not too hardly! )
| Jul17-05, 08:18 PM | #6 |
Clausius2, are you talking about a sliding scale for power rates based on the power factor for each customer?
As for the original post, does anyone know approx. how efficient these systems may be? By a seat of the pants calculation, I land around the 5% range [.9 x .2 x .3 x .9] as a best case, which is about the same efficiency as converting the excess energy into hydrogen, and offsetting peak demands by using the H2 fuel. This has a been one focus for the H2 folks and it looks like they could already be competitive. |
| Jul18-05, 02:15 AM | #7 |
| Jul18-05, 02:25 AM | #8 |
| Jul18-05, 03:24 AM | #9 |
I'm going to pretty much ignore all of the posts and comment only upon the title of the thread. All electrical generation facilities consume more power than they produce. Even a fusion plant, should an operable one be developed, would be in that category. It's only a partial conversion of one state of energy to another, with attendant losses. When you consider how much energy went into creating deuterium and tritium in the first place, it's obvious that there is really no 'break even' point. It's almost like petrochemicals, where one thinks that oil is a free resource once you get it out of the ground. That doesn't factor in the amount of solar energy and planetary gravity/heat that went into sustaining the lives of the dinosaurs and plants and then squishing them into oil.
| Jul18-05, 03:30 AM | #10 |
| Jul18-05, 04:30 AM | #11 |
power-technology.com/projects/tianhuangping -- East China Electric Power's Tianhuangping pumped storage hydroelectric project is the biggest of its type in Asia. It [...] has a total installed capacity of 1,800MW. [...] The plant design achieved an overall cycle efficiency of 70%. -- If we assume a 91.5% efficiency for the pump motor, a 91.5% efficiency for the pump, a 91.5% efficiency for the turbine, and a 91.5% efficiency for the generator, that would be an overall efficiency of 70.0945700625%. Wikipedia's pumped-storage efficiency claims are even bolder than China's. en.wikipedia.org/wiki/Pumped-storage_hydroelectricity -- Between 70% and 85% of the electrical energy used to pump the water into the elevated reservoir can be regained in this process. -- |
| Jul18-05, 01:21 PM | #12 |
the point of my post was to illuminate you to the fact that we are wasting huge amounts of power , by pumping it up hill , just to let it flow back down , when demand is higher..
the only reason this is feasable is because power is cheaper at night ( for large users) ... So they buy cheap power at night , and sell it back , at a hgher rate.. you would think that this would put a higher load on the overall system.. |
| Jul18-05, 01:55 PM | #13 |
| Jul18-05, 03:39 PM | #14 |
If someone was to build a huge capacitor network to store the power at night..
and put it back during peak demand.. that would have much more efficiency , and make more sence than all the losses associated with pumping water up hill... |
| Jul18-05, 03:52 PM | #15 |
| Jul18-05, 04:22 PM | #16 |
It would be like charging a battery, as opposed to
charging a battery while it is pumping water up hill .. there is allways losses , even when charging a battery.. but not as much , as the topic of this discussion.. |
| Jul18-05, 04:31 PM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: A power plant that uses more power than it generates
| Working in a nuclear power plant | Academic Guidance | 19 | ||
| Power plant | Introductory Physics Homework | 1 | ||
| [SOLVED] Power plant | Advanced Physics Homework | 2 | ||
| Steam Power Plant | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Creating a nuclear power plant | Nuclear Engineering | 6 | ||
