How Did Newton Derive Universal Gravitation?
The discussion revolves around understanding Newton's law of universal gravitation, including its derivation, the concept of the inverse square law, and the mathematical formulation involving two masses. Participants explore the implications of these concepts in both theoretical and conceptual contexts.
  • One participant expresses confusion about the derivation of the universal gravitation formula, questioning how Newton arrived at F=GxM1xM2/R² and the meaning of the inverse square law.
  • Another participant explains the inverse square law as a general principle where a quantity is proportional to 1/x², suggesting that the multiplication of masses is necessary for dimensional consistency.
  • Some participants note that Newton's formulation aligns with Kepler's laws of planetary motion, implying a connection between gravitational force and celestial mechanics.
  • There is clarification about the distinction between the gravitational constant (G) and the acceleration due to gravity (g), emphasizing the importance of not confusing the two.
  • One participant attempts to derive the acceleration due to gravity from the gravitational force equation, leading to a discussion about the implications of multiplying versus adding masses in the context of gravitational force.
  • Another participant provides a basic explanation of acceleration, relating it to changes in velocity over time, and offers an example involving a falling object to illustrate the concept of gravitational acceleration.
Participants generally agree on the definitions of G and g, as well as the basic principles of the inverse square law. However, there remains uncertainty and confusion regarding the derivation of the gravitational force equation and the conceptual understanding of acceleration, indicating that multiple views and interpretations are present.
Some participants express limitations in their understanding of the mathematical and conceptual aspects of the discussion, indicating that further clarification may be needed on the derivation steps and the implications of the equations involved.
This discussion may be useful for individuals beginning their studies in physics, particularly those interested in gravitational theory, mathematical formulations in physics, and the conceptual foundations of motion and force.
Beholder
:confused:
Hello I need some help understanding Newtons universal gravitation. I read on a site that an objects Force on Earth is its mass x gravity(on earth) hence MG (like F=MA). Then they say using Newtons inverse square law that the same object at a distance of the moon would have the force(g) MG/distance to moon² and so it would be that much weaker.
Now with the universal gravitation between two masses we know F=GxM1xM2/R²
my questions are how did Newton come to this conclusion?, what is the inverse square law?, and why are the two masses multiplied not added? I'm a little confused about this the only answer I can come up with is:
say we have the first equation they talked about F=MG (g for gravity on earth) if we substitute G with its components M x Gravitational constant we get two separate masses mass 1 for the object and mass 2 for the Earth and we also get G (grav. const.) so that's our GxM1xM2, now divide that by the square of the distance between them and we get the answer. Is that even close? can anyone answer where this equation comes from?
First an inverse squared law is a big generalization. Basically all the inverse square law really means is that some quantity is proportional to 1/x^2 where x is some variable of interest. so the equation y = c/x^2 (c is some constant) is a general example of an inverse square law.
The masses are multipled because if we added them we would not have the correct dimensions. 1kg + 3kg = 4kg where as 1kg x 3kg = 3kg^2
As for the actual derivation I don't really know how he came up with it. I would have started assuming g is variable, thus...
F = mg
F/m = g
g = GMe/r^2
At this point I assume the mass and radius of the Earth had rough values. I think it could be reasoned that the mass should be on top because more mass leads to a greater weight force and that the radius should be on the bottom as increasing distance from a body yields a weaker gravitational force. Thus, g can be defined as follows
g = c*Me/r^n
where c is the constant of proportionality and n is the order of the radius
how these values were determined...I have no idea, but that's a start
Essentially, Newton showed that this was the only force law that resulted in Kepler's laws for planetary motion.
Newton's constant G was first determined accurately, I think, by Cavendish, using a torsion balance.
Beholder said:
:confused:
Don't confuse G with g. Big G is the gravitational constant (6.673e-11 N m^2 / kg^2), and little g is acceleration due to gravity at the surface of the Earth (9.8 m/s^2).
[tex]F = \frac{GMm}{d^2}[/tex]
This solves for the gravitational force between them. Why do we multiply instead of add? Think of what would happen if we added. If a dust grain with a mass so close to 0 that you might as well call it 0 were on a bathroom scale, and we ADDED, the numerator of the equation would be enormous. But if we multiply, the numerator goes to 0, which is exactly what the bathroom scale would read.
Since
and
[tex]F=ma[/tex]
you can conclude that
[tex]\frac{GMm}{d^2} = ma[/tex]
You've got a little m on each side of the equation, so they cancel:
[tex]a = \frac{GM}{d^2}[/tex]
giving you the acceleration formula.
Since
and
[tex]F=ma[/tex]
:confused:
I'm still a little confused here, I'm just beginning physics and only know the basics of motion and things, its not the math that i can't work out its just the conceptual part, I mean I thought (so far) that acceleration was change in velocity divided by change in time. Although I can picture that given a distance and a velocity you can derive the acceleration but I'm not sure, any additional help would be much appreciated.
:shy:
You're approximately right that acceleration is change of velocity divided by time. Technically, that is average acceleration, but never mind for now.
When we say the acceleration due to gravity is, say, 9.8 m/s^2 near the surface of the Earth, we mean that, if you drop an object (e.g. a brick), its speed will change by 9.8 metres per second every second. So, if you drop it from rest, then after 1 second it will be traveling at 9.8 m/s. After 2 seconds, it will be traveling at 19.6 m/s, and so on.
  • · Replies 51 ·
  • · Replies 39 ·
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 0 ·
