Finding the Equation of a Rotated Cone
  • Context: Graduate
  • Thread starter Thread starter eddo
    Axis Cone
The discussion focuses on finding the equation of a rotated and translated cone given specific data points. It emphasizes that there is no single equation for a cone, which typically has a circular base and finite height. The recommended approach involves starting with the standard cone equation and applying transformations to account for rotation and translation. Additionally, for cases with excess data points, utilizing linear regression algorithms is suggested to approximate the cone equation effectively.
  • Understanding of cone geometry and equations
  • Familiarity with transformations in three-dimensional space
  • Knowledge of linear regression algorithms
  • Basic skills in data fitting techniques
  • Study the standard equation of a cone and its transformations
  • Learn about three-dimensional geometric transformations
  • Explore linear regression techniques for data fitting
  • Research methods for approximating equations from over-determined systems
Mathematicians, engineers, and data scientists involved in geometric modeling and data fitting, particularly those working with conic sections and transformations in three-dimensional space.
eddo
I have two questions. How do you find the equation of a cone given data points? I've found lots of info on the equation of a cone, but can't find anything on one that is rotated and not centered at the origin. What is the equation for a rotated translated cone?
Second, given the equation of a cone, how do you figure out the equation of the axis?
Side question: Does anyone know of a good way to find an equation of a cone given more data points than necesarry, which won't fit perfectly to the cone? Does anyone know of a good way to approximate the cone equation which takes into account more points? Thanks for any help.
There is no single equation for a cone: it has a circle as a bottom, is of finite height and has a mantle. At best you have a rotational right triangle.
I would write down the equation(s) of a standard cone. Then I would apply possible transformations, like stretching along a certain plane or whatever you allow as transformation. This gives you a couple of equations with the transformation coefficients as parameters. Finally you can try to solve for these parameters given your actual data.
If we have more data than necessary, than I would try to use a linear regression algorithm first and operate with its result instead of the raw data.
I'm not aware of a ready made answer to what you might have in mind. My solution requires some work to do.
  • · Replies 25 ·
13K
