Why in a small unit of area for a surface S in an electric field
The discussion revolves around the concept of electric flux through a small unit area in an electric field, specifically focusing on the use of the dot product between the electric field vector and the normal vector of the surface. Participants explore the reasoning behind this mathematical operation and its implications for understanding flux.
  • One participant questions why the flux is calculated using the dot product of the electric field vector E and the normal vector s, which makes an angle theta with the field.
  • Another participant uses an analogy of "wind" to explain that the dot product represents the amount of "air" passing through the surface, suggesting it is a useful visualization for understanding flux.
  • A different participant elaborates on the necessity of the dot product by discussing a scenario involving a can of coke, explaining how the orientation of the surface affects the flux and the sign convention for inward and outward flux.
  • One participant asserts that the reason for using the dot product is simply that "that's how the flux is defined," indicating a more straightforward perspective.
  • Another participant emphasizes that flux is maximized when the electric field is parallel to the surface normal and is zero when they are perpendicular, reinforcing the intuitive nature of using the dot product.
Participants express varying perspectives on the reasoning behind the use of the dot product for calculating flux, with some providing analogies and others focusing on definitions. There is no consensus reached on a singular explanation, as multiple viewpoints coexist.
Some assumptions about the definitions of flux and the orientation of vectors are present but not explicitly stated. The discussion does not resolve the nuances of these definitions or the implications of different sign conventions.
misogynisticfeminist
I am wondering why in a small unit of area for a surface S in an electric field. The flux of the small area is the dot product of E and s where s is the normal vector and makes an angle theta to the field. Why do we use the dot product of E and s, why does it give us the flux of the small area?
Visualize the electric field as "wind". The dot product tells you how much
"air" is passing through the small surface. Don't take the analogy any further
than that- it's just a good way to visualize flux and dot products.
You need to use the dot product because you need the amount "going in" to a surface. Imagine if you turn a can of coke on its side so that the circular ends are like vertical circles. Flux is the amount of whatever flowing through a given area. So like in the previous post, if the wind was perfectly vertical, nothing would enter the can from its ends. If we take the dot product of the winds direction with that of the outward normal from the ends caps we get 0. However, if the wind is perfectly horizontal we get some non zero value. (we actually need to take the negative of the dot product if we use the outward normal). That is if the outward normal of one end cap points to the left and the winds is to the right we would obtain a negative value for flux. This is incorrect as inward flux has a positive sign convention and outward flux has a negative sign convention. By taking the negative of left dot right we obtain some positive value which in this case is the magnitude of the air flow rate through the circular area of the left side of the can. In fluid dynamics flux is very important as the net flux determines whether or not a control volume maintains a steady state or not.
Simple answer : "Because that's how the flux is defined" !
To emphasise Gokul's point;
Flux is maximum when E is parallel to the surface normal, and zero when these two vectors are perpendicular. It is therefore intuitive to use a dot product to define the flux.
Claude.
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 30 ·
