Robotic Pointer: Accurate Pointing with Polar Coordinates and Stepper Motors
  • Thread starter Thread starter benzun_1999
The discussion centers around the design and implementation of a robotic pointer that utilizes polar coordinates for accurate pointing in a two-dimensional x, y coordinate plane. Participants explore the mechanical and electronic components necessary for achieving precise movement, including the use of stepper motors and gearing systems.
  • One participant describes a robotic pointer design involving two platforms that rotate around the x-axis and y-axis, seeking advice on achieving accurate degree-based rotation.
  • Another participant suggests using stepper motors for movement and mentions the possibility of using gearing or micro-stepping to improve resolution.
  • Links to resources on stepper motors and micro-stepping are provided to assist with implementation.
  • A participant expresses concern about whether stepper motors have enough torque for the application and notes their unfamiliarity with electronics.
  • There is a discussion about the necessity of gears for achieving desired resolution, with one participant noting that regular stepper motors have coarse steps and suggesting microstepper motors as an alternative.
  • One participant shares a method involving a regular stepper motor driving a fine-threaded screw shaft for linear positioning, while emphasizing the importance of calibration and limit switches.
Participants generally agree on the use of stepper motors for the robotic pointer but express differing opinions on the necessity and type of gearing required for achieving the desired resolution. The discussion remains unresolved regarding the best approach to implement the system effectively.
Participants mention various technical aspects such as torque, resolution, and backlash, but do not reach a consensus on the optimal configuration for the robotic pointer. The discussion reflects a range of assumptions about the capabilities of stepper motors and the design requirements of the system.
This discussion may be useful for individuals interested in robotics, particularly those exploring the integration of mechanical and electronic components for precise positioning systems.
benzun_1999
help me! robotic ponter
hi all!
I am currnenty working on a robotic pointer that can point any point in a x, y coordinate plane. for this i am using a structure with two platforms one on another. the platform at the bottom is attached with the platform on top of it. while one platform rotates in the x-axis another rotates in the y axis. thus enabling me to get all points. the pointer must point using polar coordinates, that is using degrees. I am trying to mechanize and computerize this here i am suffering some problems.
1. how can i turn the platform by degrees accurately? (a small mistake and the point will not be marked properly) for trying to turn the platform should i use gears? if so what will be the best ratio to turn by .5 or 1 degrees?
2. can stepper motors help? My sir adviced me to use them but i have no proper idea how to implement them.
3. how can i computerize it? i am aware of using serial port for interface and have already gone through many circuits but without the above solved the rest is in vain.
Hope u will help and suggest me.
Thanks in advance for the help.
-Benzun
You would normally use stepper motors to move your platforms. You can use gearing or "micro-steps" to get finer resolution than the simple stepper can give you. Here are a couple links:
http://www.netmotion.com/htm_files/mc_motor_dmicro.htm (vendor of stepper motors)
http://www.ams2000.com/stepping101.html (stepper motor basics)
http://motion-controls.globalspec.com/Industrial-Directory/micro_stepper_motor (search on micro stepper motors)
You could also use a servo motor technique to get finer resolution, but that is more tricky to design and get stable. You should be able to get an interface card for your PC to drive the stepper motors from National Instruments or B&B Electronics.
...And here's a good pointer into a Photonics Spectra Magazine article and advertiser about controlling x-y tables:
http://www.photonics.com/spectra/newprods/XQ/ASP/newprodidp.7201/QX/read.htm
thanks
you cleared a lot of doubt and helped me. i am thankful to u. i already got circuits that can control stepper motors from pc. Does stepper motor have enough troque to turn the disc? I am aware of noraml DC motor but these stepper motors are completely new to me (i am not a electronics student). Moreover i believe these stepper motor are also found in the computer electronic component i believe.
even if i use stepper motor i believe i must use gears?
That depends on the resolution that you want to get out of your system. A regular stepper motor has pretty coarse steps -- I think only a dozen or two per revolution. You have two choices if you need better resolution: gearing down, or using microstepper motors. The advantage of microsteppers is that you won't have the backlash that you get with a geared system when you change directions. The disadvantage is usually the cost of the microstepper motors, I think.
One thing that has worked well for me in the past for linear positioning is to use a regular stepper motor and have it drive a long screw shaft with fine threads. Then you have a shaft coupler thing (I forget the name -- it has threads on the inside and you connect the outside to the moving stage -- it's kind of like a big precision nut) that is what drives the moving stage. With fine enough threads you don't get much backlash. And you can even calibrate the backlash out by measuring it and keeping track of it when you change direction. You'll also want limit switches at the ends of your linear travel, to static the stepper motor when its linear stage makes it to the end of its travel.
I think you were focusing mainly on rotational stages, not linear stages, and gearing them down is harder usually. Microstepper motors would probably be the way for you to go. Again, just check the specifications for how many steps per revolution they can achieve, and compare that to the resolution that you hope to achieve. Good luck, -Mike-
thanks for ur help
