timberfella
- 3
I need to simulate a test weight of between 10 and 20 Kg on top of a product. I am planning to do this by compression, via a steel plate directly attached to the arm of a pneumatic cylinder. The product, (and steel plate), dimensions are 5 1/2" x 1 5/8", (or 14cm x 4.1cm for you youngsters!). Am I correct in assuming that I need to apply a pressure of between 2.8 lbs/sq in, (0.17kg/sq cm), and 5.6 lbs/sq in, (0.35kg/sq cm), to the top of the pneumatic piston, regardless of the size of that pneumatic piston?
