Magnetic Field and Induced Currents in Rails Problem
The discussion revolves around a problem involving a uniform magnetic field and a metal rod sliding on rails within that field. Participants explore whether an induced current occurs when the rod is moved and the implications of magnetic flux changes in this context.
  • Some participants attempt to clarify the conditions under which induced current occurs, referencing concepts like magnetic flux and Lenz's law. Others question the assumptions regarding the uniformity of the magnetic field and the nature of flux changes when the rod is moved.
The discussion is active, with participants offering insights into the relationship between motion, magnetic flux, and induced current. There is a mix of agreement and questioning regarding the underlying principles, with some participants suggesting that the movement of the rod alters the area through which the magnetic field lines pass, thus changing the flux.
Participants note that the circuit must be closed for current to flow and discuss the implications of the rod's displacement on the magnetic flux. There is an emphasis on understanding the conditions necessary for current induction without reaching a definitive conclusion.
phyphysics
Consider the following problem:
There is a uniform magnetic field pointing into the page. A set of rails is placed horizontally inside the field. A metal rod can slide freely on the rails, when we apply a force to move the rod to the right, is there any induced current in the rod when moving it inside the uniform field?
Yes there is current if the circuit is closed.
[tex]E = bvB \sin{\alpha}[/tex], here [tex]\alpha = \pi[/tex].
You can deduce the latter from this: [tex]E = \frac{d \Phi}{dt}[/tex] when you remember that [tex]A (t) = ab (t) = vtb[/tex].
yes there will be an induced current. The direction of that current will be so that the resulting Lorentz force on the rod will counter the force you exterted when pushing the rod to the right.
marlon
But isn't that the wire does not encounter any change in magnetic flux? How can current be induced if the magnetic flux does not change?
why do you think the flux isn't changing? what's the effect of sliding the metal bar to the right?
in order to change the flux you can alter two variables:
1) the magnitude of the B field, but this is constant here
2) the surface through which the B lines pass, this changes because of the rod-displacement
marlon
But how can current be induced when it moves along the UNIFORM magnetic field?
because the flux changes
or
because you have a moving wire in a magnetic field. Don't you know what Maxwell says about this ?
marlon
So what exactly are the conditions for current to be induced?
Well, a changing flux induces an EMF and thus a current, that is all.
If the flux rises, then the induced current will have such a direction that the associated induced B field will counter act to the rising flux. this is just Lenz's law in a more general form
Also, according to the Lorentz-force formula, you know that if a wire moves in a magnetic field, a current must flow through that wire
marlon
Simply, if the circuit is closed it means some other connection between the two rails. Then this connection with rails and the rod encloses some area and this area is changing due to movement of the rod, hence the flux through this area is changing, inducing current.
