How Does the Limit Sum Integer Method Solve Integral Calculations?
The discussion revolves around the application of the Limit Sum Integer method, specifically in the context of calculating the integral \(\int_{2}^{10} x^6 \; dx\). Participants explore the method's formulation, its relation to Riemann sums, and the steps involved in evaluating the integral using this approach.
  • One participant asks how to solve the integral using the Limit Sum Integer method.
  • Another participant suggests that the Limit Sum Integer method is likely referring to a Riemann sum, noting that Riemann sums are typically calculated with even spacing.
  • A third participant states that the integral can be directly evaluated using the fundamental theorem of calculus, providing the antiderivative as a check on the work.
  • There is a proposal that the Riemann sum should be expressed differently, with a specific formulation involving the term \(\left( 2 + \frac{i(10-2)}{n} \right)^6\).
  • One participant outlines their approach to the integral, indicating that the Riemann sum must be expanded before summing the polynomial.
Participants express differing views on the formulation of the Riemann sum and the necessity of expanding the polynomial before summation. There is no consensus on the best approach or the correctness of the formulations presented.
Some participants highlight potential ambiguities in the definitions and formulations used, particularly regarding the spacing in the Riemann sum and the steps required to evaluate the integral.
Orion1
How is this problem solved using the Limit Sum Integer method?
[tex]\int_{2}^{10} x^6 \; dx[/tex]
Limit Sum Integer method is an odd name.
I assume you mean as a Reiman sum. Usually the Reiman sum is calculated with even spacing.
[tex]\int_{2}^{10} x^6 \; dx=\lim_{n\rightarrow\infty}\sum_{i=1}^n (x^*_i)^6{\Delta}x_i=\lim_{n\rightarrow\infty}\sum_{i=1}^n (2+i(10-2))^6\frac{(10-2)}{n}[/tex]
Thus all that is needed to work through to the end is the ability to do sums of polynomials.
Of course, to anyone who actually knows how to do an integral,
[tex]\int_2^{10}x^6dx= \frac{1}{7}x^7[/tex] evaluated between 2 and 10. You can use that to check your work.
Riemann Sum...
lurflurf said:
[tex]\lim_{n\rightarrow\infty}\sum_{i=1}^n (2+i(10-2))^6\frac{(10-2)}{n}[/tex]
Should not this Riemann sum actually be:
[tex]\lim_{n\rightarrow\infty}\sum_{i=1}^n \left( 2 + \frac{i(10-2)}{n} \right)^6 \frac{(10-2)}{n}[/tex]
This was my approach:
[tex]\int_2^{10} x^6 dx = \lim_{n \rightarrow \infty} \frac{8}{n} \sum_{i = 1}^n x^6 = \lim_{n \rightarrow \infty} \sum_{i = 1}^n \left( 2 + \frac{8i}{n} \right)^6 \cdot \frac{8}{n}[/tex]
This Riemann sum must be expanded before one can sum the polynomial?
  • · Replies 16 ·
