The Arrow of Time: Entropy & System Evolution
  • Context: Graduate
  • Thread starter Thread starter paco1955
    Arrow of time Time
The discussion centers on the principle that the total entropy of a closed system and its environment always increases over time, as articulated by the second law of thermodynamics. An example involving an ice cube in hot water illustrates this concept: while the entropy of the hot water decreases as it cools, the entropy of the melting ice increases significantly more, resulting in a net positive change in entropy. This demonstrates that any local decrease in entropy is compensated by a greater increase elsewhere, ensuring that the overall entropy continues to rise.
  • Understanding of the second law of thermodynamics
  • Familiarity with concepts of entropy and its measurement
  • Basic knowledge of thermodynamic systems
  • Ability to analyze heat transfer processes
  • Research the implications of the second law of thermodynamics in real-world systems
  • Study entropy calculations in various thermodynamic processes
  • Explore the concept of closed vs. open systems in thermodynamics
  • Investigate applications of entropy in fields such as information theory and statistical mechanics
Students of physics, thermodynamics enthusiasts, and professionals in engineering or environmental science who seek to understand the fundamental principles governing system evolution and entropy changes.
paco1955
it is the change in entropy that ultimately provides us with the answer to why systems will naturally evolve in one direction with time and not the other: systems always evolve in time in such a way that the total entropy of system + environment increases. If you observe a system in which the entropy appears to decrease, you can be sure that somewhere there is a change in the entropy of the environment large enough to make the total entropy change positive. for example, suppose that in a closed system i drop an ice cube in a container full of hot water. heat will flow from the hot water to the ice. the temperature of the hot water drops and the ice melts simultaneously until both bodies of water reach the same temperature and form a homogeneous luke-warm body of water. the cooling process of the hot water is a negative entropy change. in other words, the entropy of the hot water decreases. (the hot water changes from a relatively disorganized state to a more organized state.) the melting process of the ice is a positive entropy change. in other words, the entropy of the ice increases. (the ice changes from a relatively organized state to a more disorganized state.) it turns out that the positive entropy change of the ice is greater than the negative entropy change of the hot water. in other words, if you observe the hot water in which the entropy appears to decrease, you can be sure that there is a change in the entropy of the ice large enough to make the total entropy change positive. if "sh" is the negative entropy change of the hot water (sh < 0) and "si" is the positive entropy change of the ice (si > 0), then sh + si > 0.
Science news on Phys.org
That makes a lot of sense! So basically, the total entropy of the system and environment always increases, even if the entropy of one part of the system (like the hot water in this example) appears to decrease. This is because the entropy change in the other part of the system (like the ice in this example) is greater than the entropy change in the first part. Thank you for explaining this concept so clearly!
  • · Replies 17 ·
  • · Replies 65 ·
14K
