| Thread Closed |
Consecutive fans |
Share Thread | Thread Tools |
| Jul30-05, 10:36 PM | #1 |
Consecutive fans
If you have two hurricane fans, and place them one after another, both blowing the same direction, will the air from the front fan be twice as fast?
| Jul31-05, 12:01 AM | #2 |
Well, I don't know what a hurricane fan is, but the answer is no.
The speed of the second fan relative to the air will not cause the air to speed up twice as much. |
| Jul31-05, 02:07 AM | #3 |
Dave is right. When you have equal characteristics fans(i.e equal head and flowrate) series arrangement gives you the capacity of a single fan but head gets doubled. Parallel arrangement gives you double the capacity of a single fan but head remains same.
| Aug3-05, 09:25 PM | #4 |
Consecutive fans
The fan speed will not increase by putting one behind another, but by putting them next to each other will create a greater area covered and more of a "breeze" effect. Both Dave and quark were correct
| Aug3-05, 11:35 PM | #5 |
Mentor
Well, there was recently a thread where someone complained about water flow being used as an analogy for electricity. Well, here it is again: as others correctly said - parallel vs series configuration means more flow (amperage, flow) vs more pressure (voltage, head).
edit: If you internalize this concept (that energy transfers/flows of all types are related), you'll be waaaaay ahead of the curve as an engineer. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Consecutive fans
| Non-Consecutive Fibonacci Numbers... | General Math | 6 | ||
| consecutive number problem | Calculus & Beyond Homework | 3 | ||
| counterexample so that (ab)^i=a^ib^i for two consecutive integers | Linear & Abstract Algebra | 4 | ||
| what is the space between two consecutive grooves on the CD | Classical Physics | 1 | ||
| adding consecutive squares? | Introductory Physics Homework | 8 | ||
