Thread Closed
Does the Speed of Light Change depending on different Light Frequencies?
Share Thread Thread Tools
Jul31-05, 04:53 AM   #1
We all know that light speed in a vacuum is constant and travels 9.8 X 1018 meters in a year. Now since light travels in waves instead of a straight line, if the wave was then uncurved, it would cover more distance than when it was in its original state. Of course different lights have different frequencies so a wave with a higer frequency must cover more ground than waves of lower frequencies like red.
But if a radiowave was put next to a lightwave and both where pointed to the same destination, based on the Einstein's constant rule, both will hit the wall at the same time. My questions is, is the higher frequency wave faster than the lower frequency wave since it had to cover more distance to hit the same destination at the same time? Does this mean that the speed of light is different at each frequency?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jul31-05, 05:02 AM   #2
Quote by PhysicsEnthusiast
No, A low energy radio wave, inside a Vacuum, will propergate at a constant Velocity, equal to that of the High Frequency Lightwave.
Inside a Vacuum Chamber they are indistinguishable, a Low energy RW gains velocity from the Vacuum Pressure.
Jul31-05, 05:07 AM   #3
Mentor
No, it doesn't. If it does, than Einstein would have put in his postulates the PARTICULAR frequency in which he claims to have a constant speed.
The varying frequencies dependent is typically more of the consequence of the MEDIUM, not on light. This is where the frequency will make a difference. The fact that we have not detect ANY difference in speed of light in vacuum[1,2] for any frequency is an argument against the idea that light travels in a "medium" when it moves through vacuum.
Zz.
[1] "Severe Limits on Variations of the Speed of Light with Frequency", B. Schaefer, PRL v.82, p.4964 (1999). See summary at http://www.aip.org/enews/physnews/19...t/pnu432-2.htm.
[2] M. Fullekrug, PRL v.93, p.043901 (2004).
Jul31-05, 06:57 AM   #4
I read his article. I was wondering what (Delta c/c), (Mgamma), and (Eqg) stand for.
For example:
- for the frequency that is (Delta c/c), what numbers do I use to replace those inside the brackets?
- for the quantum gravity that is (Eqg), what is the given number?
- for the photon's mass (Mgamma), since photon's have zero mass, would I replace the "Mgamma" witha zero?
Thanks.
Jul31-05, 07:13 AM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
First, your argument about "straightening" the wave and looking at the length of that doesn't make much sense. Light consists of electro-magnetic waves, not waves in any physical substance that can be "straightened".
As ZapperZ said, while the speed of light in vacuum is constant, in some medium other than vacuum, it does depend upon frequency. That's why different colors of light bend different angles going through a prizm.
Jul31-05, 05:31 PM   #6
Recognitions:
I think the OP imagines that light travels along a sinusoidal path - so the greater the frequency, the greater the path length, and hence, the greater the "actual" speed.
Also, straightening out, must refer to stretching out the sine curve to a straight line.
Aug4-05, 12:11 PM   #7
You perhaps will profit from considering a wave of temperature in a large plane metal plate. The possibly sinusoidal shape of the propagating temperature profile have nothing to do with the distance the peak of the wave travel during a given time interval. Electric field is not until now (to the extent of my knowledge, of course) related to metric. But I believe it may be involved in it, but this is only a speculation.
Note: temperature propagates in a plane metal plate according to a different equation, not the wave equation. But even so, I think, this fictitious example may clearify some points in this discussion.
Aug5-05, 03:16 AM   #8
Recognitions:
As Halls and Gokul have alluded to, it appears to be a misinterpretation of the wave nature of EM. The light does not follow a sinusoidal path; it is one (2 actually, since the electric and magnetic fields are separate). The only way to flatten it is to decrease the frequency to zero, which will automatically increase the wavelength to infinity in order to maintain the mandated speed of 'c'. In other words, shut the lights off.
Aug5-05, 05:14 AM   #9
Hmm---but what if not in a vacuum?
I'm learning Physics C (from Barron's Review, I admit!), and I am not yet at the EM chapters. However:
Would higher frequency EM waves travel at speeds closer to [itex] c [/itex]?--->
I mean,
*Let's say you have a tank of still water, and you shine some light through it. Water will interfere/"slow down" the light passing through it, and its speed will be less than [itex] c [/itex]. Now, you shine another EM wave through it, this time one with HIGHER frequency than the original light you shined through the tank.
*Will the higher frequency light be "Less" affected by water's resistance?? (More energy to the beam, more mass--if that concept of relativistic mass applies??) WIll the Higher frequency light experience/feel "less" resistance to the water than the original light?---and will thus beam faster through the tank? Anyone??
Aug5-05, 05:18 AM   #10
Community 2012
Recognitions:
No, they will still travel at teh same speed. Light has no mass so there is no inertia to be affected by the water.
Aug5-05, 05:28 AM   #11
Recognitions:
Quote by Pengwuino
That's sort of a yes-and-no situation. By definition, whatever speed the light is travelling at is 'c'. While there will be no inertial interactions, the refractive index of any medium will affect the travel characteristics of light passing through it. For instance, X-rays will take a lot less time getting through a piece of oak than red light will.
Aug5-05, 05:47 AM   #12
Community 2012
Recognitions:
Hmm why does that happen. I thought they would just go slower then 300,000km/s but would both go at the same speed..
Wait i take that back. I still dont get it. How can they slow... wait... ok im sleepie, ill read something in the morning.
Aug5-05, 06:10 AM   #13
Recognitions:
Quote by Pengwuino
The speed of the individual photons is the same, but some are able to take a more direct route than others so the forward propogation speed varies.
Aug5-05, 01:05 PM   #14
Quote by Danger
But suppose we have a block of wood. If both rays enter normal to the block, and neither is angularly deflected via refraction,
*then both rays will pass through the block at the same speed regardless of frequency?
But doesn't wood/water/etc... "slow down" the speed of the light to less than [itex] c [/itex] ? Wouldn't a higher frequency beam observably feel/experience less resistance from the medium (w/more E per photon)?
Aug6-05, 03:05 AM   #15
Recognitions:
Quote by bomba923
If you're not familiar with the game "Pachinko", this might not make sense, but I'm going to use it as an analogy anyhow. In that game, a bunch of steel balls about 5mm in diameter are simultaneously dropped down a vertical playfield with a bunch of pegs, traps, etc.. along the way. (Like a vertical low-tech pinball without flippers.) Although each ball is accelerating downward at 1g, they all experience different interactions on the way. If one were lucky enough to miss everything, it would drop from top to bottom at a constant 1g. Every time one is deflected, however, adds to its total travel time. It doesn't slow down to any appreciable degree, but the detours make it stay in play a lot longer. They all eventually hit the bottom, but at widely varying times.
In the case of EM radiation, the higher the frequency the fewer 'pegs' it hits on the way through.
Jul18-08, 03:56 PM   #16
Yes, NASA and other space agencies have found very slight differencies (which surprised them).
Space seems to a cause a 'group delay' problem and means that parts of signal (different sidebands) arrive before others causing distortion.
Thread Closed
Thread Tools
Similar Threads for: Does the Speed of Light Change depending on different Light Frequencies?
Thread Forum Replies
Light speed....Impossible Faster than light..Probable? General Physics 5
Real time effects of light, light speed, and the sun? General Astronomy 4
Speed of light Schmeed of light: things can travel faster Special & General Relativity 13
Change of speed of light in a gravitational field Special & General Relativity 9
French scientists discover method to change the speed of light. General Physics 9
