The Tire's Velocity at the Embankment's Top: 2.8 m/s
  • Thread starter Thread starter huskydc
    Velocity
The discussion centers on calculating the velocity of a tire at the top of an embankment after rolling up at an initial speed of 2.8 m/s. The tire has a mass of 10 kg and a radius of 30 cm, and it ascends a 30° ramp for 1 meter. Using the conservation of energy principle, the correct moment of inertia for the tire, approximated as a solid cylinder, is I = 0.45 kg*m². The final velocity at the top of the embankment is determined to be 5.2 m/s, assuming no friction or air resistance.
  • Understanding of conservation of energy principles
  • Knowledge of moment of inertia calculations for rotating bodies
  • Familiarity with kinetic and potential energy equations
  • Basic trigonometry for calculating height from ramp angle
  • Study the conservation of energy in mechanical systems
  • Learn about moment of inertia for different shapes, including hoops and cylinders
  • Explore the effects of friction and air resistance on rolling objects
  • Practice solving similar problems involving inclined planes and rotational motion
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rolling objects and energy conservation in motion.
huskydc
a tire, rolls up on a ramp,
with a speed of 2.8 m/s, a tire mass of 10 kg and tire radius of 30 cm
the tire cruises up an embankment at 30° for 1 meter
What is the velocity of the tire at the topof the embankment in m/s?
I tried the following:
energy conservation: and end up with something like this:
Final KE =
[ 1/2*M*V^2 + 1/2*I*(V/R)^2 ] - M*g*h (where h = 1m * sin30° )
and I = .45
but I'm not sure if at Final KE, that if there is still the rotational energy, however, I tried solving for V
with both either KE as just .5 m v^2 and .5mv^2 + .5 I (v/r)^2
neither works...hints?
Final KE =
and I = .45
It appears you are on the right track. There is initial kinetic energy of translation and rotation, and final kinetic energy with the difference between them being the potential energy. The kinetic energy will always be a combination of both translation and rotation as long as the tire is moving.
It appears you are using the equation for a disk to find I. A tire is not a disk. A reasonably accurate model would be a hoop or ring, with all the mass at approximtely the same radius. That is not precise, but it may be the assumption you are expected to make.
It seems like you are on the right track with using energy conservation to solve for the velocity of the tire at the top of the embankment. However, there are a few things to consider in your calculations.
First, make sure that the value you are using for the moment of inertia (I) is correct. The moment of inertia of a solid cylinder (which is what a tire can be approximated as) is given by I = 1/2 * M * R^2, where M is the mass of the object and R is the radius. In your case, I would use I = 1/2 * 10 kg * (0.3 m)^2 = 0.45 kg*m^2.
Secondly, when using the conservation of energy equation, you need to make sure that all the terms have the same units. In this case, your kinetic energy terms have units of Joules (J), while your potential energy term has units of Newton-meters (Nm). To make them consistent, you can convert the potential energy term to Joules by multiplying it by the acceleration due to gravity (9.8 m/s^2). So your final equation should look like this:
[1/2 * 10 kg * V^2 + 1/2 * 0.45 kg*m^2 * (V/0.3 m)^2] - 10 kg * 9.8 m/s^2 * 1 m * sin(30°) = 0
Simplifying this equation, you should get:
0.5 V^2 + 0.075 V^2 - 49 = 0
Solving for V, you should get V = 5.2 m/s. So the tire's velocity at the top of the embankment is approximately 5.2 m/s.
One thing to note is that this calculation assumes that there is no friction or air resistance acting on the tire. If there is friction, it will affect the tire's velocity as it rolls up the embankment. Also, make sure to double check your calculations and units to make sure everything is consistent. Hope this helps!
