Benny
- 577
Hi can someone please help me out with the following DE question. I'm reading ahead so as to enable myself to keep up to date so I don't how the part in italics(below) can be used so could someone please explain it to me. I'm also having trouble with the ODE itself.
Q. Given that y = x^7 is a solution of [tex]x^2 y'' - 12xy' + 42y = 0[/tex]...(1), find the general solution of [tex]x^2 y'' - 12xy' + 42y = 280x^2 + 150x - 168[/tex]...(2).
Hence find a second linearly independent solution of (1) and a particular solution of (2).
Here is what I've tried. I think this is one of those DEs with a 'partially known complimentary solution.'
Let y = u(x)v(x) = (x^7)v. Then:
[tex] y' = 7x^6 v + x^7 \frac{{dv}}{{dx}}[/tex]
[tex] y'' = 42x^5 v + 7x^6 \frac{{dv}}{{dx}} + 7x^6 \frac{{dv}}{{dx}} + x^7 \frac{{d^2 v}}{{dx^2 }} = 42x^5 v + 14x^6 \frac{{dv}}{{dx}} + x^7 \frac{{d^2 v}}{{dx^2 }}[/tex]
Substituting into equation (2) and simplifying I get:
[tex] x^9 \frac{{d^2 v}}{{dx^2 }} + 2x^8 \frac{{dv}}{{dx}} = 280x^2 + 150x - 168[/tex]
[tex] \frac{{d^2 v}}{{dx^2 }} + \frac{2}{x}\frac{{dv}}{{dx}} = 280x^{ - 7} + 150x^{ - 8} - 168x^{ - 9} [/tex]
This is a first order linear ODE in dv/dx.
[tex] IF = \mu \left( x \right) = \exp \left( {\int {\frac{2}{x}dx} } \right) = x^2 [/tex]
[tex] \frac{d}{{dx}}\left( {\mu \left( x \right)\frac{{dv}}{{dx}}} \right) = \mu \left( x \right)\left( {280x^{ - 7} + 150x^{ - 8} - 168x^{ - 9} } \right)[/tex]
[tex] \Rightarrow x^2 \frac{{dv}}{{dx}} = \int {\left( {280x^{ - 5} + 150x^{ - 6} - 168x^{ - 7} } \right)} dx[/tex]
[tex] \Rightarrow \frac{{dv}}{{dx}} = - 70x^{ - 6} - 30x^{ - 7} + 28x^{ - 6} + c_1 x^{ - 2} [/tex]
Hmm nevermind about this part...I realized that when I did this on paper I wrote (d/dx)(IFv) rather than (d/dx)(IF(dv/dx)). Anyway the general solution I get, and according to answer it is correct, is:
[tex] y = 14x^2 + 5x - 4 + c_2 x^6 + c_3 x^7 [/tex]
Can someone tell me how to find a second linearly independent solution of (1) and a particular solution of (2) from the general solution that I have found? Any help would be good thanks.
Edit: A while ago when I did questions where you substitute y = Ae^(rx) as a solution, ie. the ones where you have an auxillary/characteristic equation and you solve for the roots to find the solution to the DE, the particular solution was the 'non-complimentary' of the general solution.
Comparing those sorts of questions with the general solution I found - The arbitrary constants suggest to me that (c_2)(x^6) + (c_3)(x^7) is a solution to the homogeneous equation while 14x^2 + 5x - 4 is a particular solution. Is that how the I am supposed to deduce a particular solution to (2)? Also, how would I deduce a second linearly independent solution of (1)? When I did the easier questions involving characteristic equations I simply multiplied the particular solution, I think it was, by x whenever there was a repeated root, not sure if that is related to this though.
